Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Toilets and Sinks > How not to Set a Toilet
Thread Tools Display Modes
Old 03-30-2010, 02:48 PM   #1
Mr_David
Easily Amused
Mr_David's Avatar
Liked 852 Times on 693 Posts
Likes Given: 568
Default How not to Set a Toilet
Had a service call for very bad sewer odor.
Water closet was recently replaced.
This is what I found when I pulled the WC.
a.k.a. Krazedav
Mr_David is offline
Old 03-30-2010, 03:51 PM   #2
Chris
Administrator
Chris's Avatar
Liked 931 Times on 786 Posts
Likes Given: 67
I think someone had one to many that day.
Chris is offline
Old 03-30-2010, 06:28 PM   #3
havasu
Administrator
havasu's Avatar
Liked 1109 Times on 901 Posts
Likes Given: 327
Well, they didn't hit the bulls eye, but came pretty close!
havasu is offline
Old 03-30-2010, 08:23 PM   #4
Admin
Administrator
Admin's Avatar
Liked 106 Times on 98 Posts
Likes Given: 244
Did you ask who the prevous plumber was?
Admin is offline
Old 03-30-2010, 08:33 PM   #5
phishfood
Administrator
Liked 964 Times on 775 Posts
Likes Given: 1739
Really, having set secveral hundred toilets over my career, I am having trouble figuring out how the guy before you managed to do that.
But, at least they used a wax ring.
I did one a while back on a 9 year old house. The plumber had completely forgotten to use a wax ring, but did a VERY good job grouting the toilet down. It had finally started seeping, and when I broke the water closet loose, a tidal wave of black "water" flooded the toilet room.
phishfood is offline
Old 03-31-2010, 03:35 PM   #6
specgrade
Liked 5 Times on 5 Posts
Likes Given: 16
Oooppss. My only guess is that once the toilet was down it was picked up again, the wax ring fell away from the toilet and ened up where it is now.
specgrade is offline
Old 04-01-2010, 03:24 PM   #7
majakdragon
Another example of why I place the wax seal on the flange and use the mounting bolts as a guide when I set the toilet.
If you have never made a mistake, you probably haven't done much.
majakdragon is offline
Old 04-01-2010, 08:49 PM   #8
havasu
Administrator
havasu's Avatar
Likes Given: 327
Quote:
I've always placed the wax seal on the toilet. This way, I can form a good seal on the porcelain. Is this incorrect?
havasu is offline
Old 04-01-2010, 08:59 PM   #9
SilverBack4Jack
Always Learning.....
SilverBack4Jack's Avatar
I wouldnt say incorrect since most manufacturers show you putting the wax seal on the toilet in their diagrams. It just seems easier to some of us to do it the way majakdragon does his. I have always placed mine on the flange and the used the bolts as a guide as well. I have never had one not seal against the toilet this way.
Well you see what had happened was....
SilverBack4Jack is offline
Old 04-01-2010, 09:06 PM   #10
havasu
Administrator
havasu's Avatar
Likes Given: 327
SB4J, Thanks for the input! I'll give it a shot next time I set a toilet.
havasu is offline
Tags
inproper, toilet, setting, sewer smells, incorrect
Newest Threads
