Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Plumbing Noise after flushing toilet????
Thread Tools Display Modes
Old 01-01-2013, 06:57 PM   #1
jr235
Default Plumbing Noise after flushing toilet????
When we flush the toilet, there is a knocking noise in the plumbing system. sounds like it is in the pipes all way up the the hot water tank in the attic. We just had a recirculation pump put in for improved hot water issues. What could be causing these knocking sounds that last about 2 minutes after flushing a toilet? Thanks for any help, Ron
jr235 is offline
Old 01-01-2013, 11:38 PM   #2
DetroitRob
DetroitRob's Avatar
Liked 11 Times on 11 Posts
It sounds like unsupported piping banging around.
DetroitRob is offline
Old 01-02-2013, 12:13 AM   #3
IFIXH20
HERE TO HELP
Liked 236 Times on 187 Posts
Likes Given: 165
Does it happens with all your toilets or just one particular toilet ?
IFIXH20 is offline
Old 01-02-2013, 01:49 AM   #4
jr235
Default plumbing noise flushing toilet
Mainly from the guest bedroom toilet, we have 3 1/2 bathrooms
jr235 is offline
Old 01-02-2013, 10:48 PM   #5
IFIXH20
HERE TO HELP
Likes Given: 165
The guest bath toilet fill valve and/or stop (shutoff valve) may need replacing if the noise is not that present at the other fixtures.
IFIXH20 is offline
Old 01-02-2013, 11:56 PM   #6
stevemachine
stevemachine's Avatar
Liked 115 Times on 99 Posts
Likes Given: 97
Sometimes shut off valves that are half open can cause water hammer, I would check that first. I've experienced that before for sure
stevemachine is offline
Old 01-03-2013, 06:45 AM   #7
Haworthplumbing
Haworthplumbing's Avatar
Has it always done this? The drain pipe could be passing through a very tight hole and be contracting then expanding again due to temperature change.
Haworthplumbing is offline
Old 01-05-2013, 05:28 AM   #8
pursable
pursable's Avatar
I agree with ifixh2o the toilet fill valve could be bad and needs replacing or repair or possible shut off valve rubber washer inside has come loose inside valve and is vibrating when water is running thru it. I have run into this alot because shut off valves have gotten alot cheaper and the manufactures have just press fit the rubber washer onto a stem inside the valve. Not a great design.
pursable is offline
Toilet not always flushing properly. jkirksey1889 Toilets and Sinks 5 06-15-2012 07:20 PM
Reduce the noise for plumbing pipes goofy78270 General Plumbing Help 4 03-02-2012 02:16 AM
Toilet Flushing Issue mdalasta Toilets and Sinks 1 12-05-2011 12:17 AM
Toilet Flushing psk09 General Plumbing Help 1 10-12-2011 09:18 PM
Slow Flushing Toilet? Kawiski Toilets and Sinks 3 07-08-2010 03:26 PM
Newest Threads
