Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Water Heaters and Softeners > Will a Gearwrench 1-1/2" 6pt. Socket remove a water heater element?
Thread Tools Display Modes
Old 01-01-2013, 05:46 AM   #1
rockriver
Default Will a Gearwrench 1-1/2" 6pt. Socket remove a water heater element?
Will the Gearwrench 1/2" Drive 1-1/2" 6pt. Socket 80679 work to remove an electric water heater element?
Has any one used a 1-1/2" 6pt. shallow socket to remove a water heater element? Water heater elements are only on electric water heaters, not on gas water heaters.
Can I use a shallow socket or do I need a deep socket?
rockriver is offline
Old 01-01-2013, 07:23 AM   #2
stevemachine
stevemachine's Avatar
Liked 115 Times on 99 Posts
Likes Given: 97
That should work I believe.
stevemachine is offline
Old 01-01-2013, 07:26 AM   #3
stevemachine
Likes Given: 97
I've only used deep socket and that works the best. And if recommend a powered impact or something of the sort, it can be insanely hard to remove by hand in my experience, in some cases at least.
Can I remove this pipe next to water heater? lucymiella Water Heaters and Softeners 14 09-07-2012 12:39 PM
Any point in 1" supply if water heater is 3/4"? rgeorgejr General Plumbing Help 2 03-13-2012 07:08 AM
Loss of hot water pressure and pipes "vibrate" Mr_Fantastic Showers and Tubs 3 05-20-2011 10:24 PM
Pex water line - connect to 1/2" or 3/4" source SnoSheriff General Plumbing Help 1 03-21-2011 01:47 PM
Lower Element for Marathon MX85255 deanosan Water Heaters and Softeners 2 12-06-2010 01:28 PM
Newest Threads
