Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Drain and Sewer Cleaning > Pop-Up Drain Stopper with "D" Cut/Half Moon
Thread Tools Display Modes
Old 12-28-2012, 09:41 PM   #1
FF_IN_MN
Default Pop-Up Drain Stopper with "D" Cut/Half Moon
Hey guys,
Sorry if this has been posted before, but I thought I was making good headway taking the knob off and expecting to see a shaft that I could simply unscrew with a phillips and take the stopper completely off. Instead I found what looks like a "D" Cut/Half moon key hole. Images attached.
My question is how do I get this damn thing off? Looking down that keyhole, I don't see any spot where I can grab onto with a screwdriver or a needle nose (if I even get can one down there).
Any help you guys can send my way is appreciated, thanks in advance.
FF_IN_MN is offline
Old 12-30-2012, 03:44 PM   #2
johnjh2o
johnjh2o's Avatar
Liked 696 Times on 529 Posts
Likes Given: 581
While holding the stopper up try to unscrew it.
John
johnjh2o is offline
Old 12-30-2012, 08:44 PM   #3
FF_IN_MN
Quote:
John
What is in the pictures is what was revealed after I had already unscrewed the knob. The "D" cut piece is well attached to the stopper itself.
Anybody have any other ideas?
FF_IN_MN is offline
Old 12-30-2012, 08:56 PM   #4
johnjh2o
johnjh2o's Avatar
Likes Given: 581
Like I said hold the stopper up and unscrew it. It should unscrew from the shoe.
John
johnjh2o is offline
phishfood Likes This
Old 12-30-2012, 09:06 PM   #5
stevemachine
stevemachine's Avatar
Liked 115 Times on 99 Posts
Likes Given: 97
Yeah if that doesn't work, some have screws in the side of the stem. I think johns right though, lift up and try and un thread it. I have never came across this type before
stevemachine is offline
Old 12-30-2012, 09:30 PM   #6
johnjh2o
johnjh2o's Avatar
Likes Given: 581
I believe what the D-slot is for is a tool to unscrew stopper. But the stopper must raised for it to unscrew. I am not 100% sure of this but it's worth a try.
John
johnjh2o is offline
Old 12-30-2012, 10:20 PM   #7
stevemachine
Likes Given: 97
Makes sense to me John.
Old 12-31-2012, 01:18 AM   #8
FF_IN_MN
John
Unscrew what? That raised part? Is welded on there.
FF_IN_MN is offline
Old 12-31-2012, 01:23 AM   #9
FF_IN_MN
Got it figured out...the stopper had to be in the plug/stopped/lower/down position to unscrew it. Thanks for the help.
FF_IN_MN is offline
Old 12-31-2012, 01:27 AM   #10
stevemachine
Likes Given: 97
I think what John meant was if you lift it up and maybe put a slotted screw driver into the half moon, the whole piece should come out. If it doesn't come out then it my be stripped or corroded on. If you get really desperate you could try going underneath and prying, I wouldn't go too crazy cause it may disturb the putty in the drain and cause a leak. It's kinda hard to diagnose some stuff online, even though its something as simple as this, sometimes you need to physically be there to be able to do it and try different methods based on what you see. But give those ideas a shot and see how it goes, best of luck!
2" drain pipe to 1.5" sink pipe Bogucki General Plumbing Help 3 10-27-2012 04:18 PM
Adjustable "Metric" and "SAE" wrenches? havasu Plumbing Tools and Equipment 3 04-12-2011 06:58 PM
Outside spigot with plastic "winterizing" piece causing leak thunderbry General Plumbing Help 2 06-19-2010 01:09 PM
Vice President Joe Biden or Jeff Dunhams "Walter" SilverBack4Jack General Discussion 5 01-30-2010 01:53 AM
Newest Threads
