Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Advice on replacing main sewer pipe please
Thread Tools Display Modes
Old 12-11-2012, 06:28 AM   #1
BasicPoke
Default Advice on replacing main sewer pipe please
I need to replace the pipe from my house to my septic tank, because it is partially collapsed (on the lower portion, which is thinner pipe), and install a cleanout. The house was built in 1977. The pipe coming out of the slab is fairly thick and is stamped PLASTIC in black. Diameter is 4 1/2 inches. As you can see, it goes through a multitude of connections, some of which I don't understand (it looks like a smaller pipe was just slipped inside a larger pipe). The elevation needs to drop about 1 ft. Any advice will help. See attachments.
Questions:
1. What is this type of old main pipe called and how do I connect to it?
2. Do I likely just need a standard 4" pipe into the septic tank?
3. How should I seal the pipe to the septic tank inlet (It goes thru a round hole that is roughly 4" but a bit larger)?
Thanks a lot
BasicPoke
IMG_8824_25%.JPG   IMG_8826_collapsed part.JPG   IMG_8828_25%.JPG   IMG_8829_25%.JPG
BasicPoke is offline
Old 12-11-2012, 12:38 PM   #2
johnjh2o
johnjh2o's Avatar
Liked 726 Times on 550 Posts
Likes Given: 620
It looks like the line through the slab is SCH 40 PVC. Then it connects to 3034 PVC. I would suggest you use all SCH 40 PVC. Cut the existing line behind the hole that was cut into the pipe. Start out with a clean out tee. Followed by two 45's and SCH 40 pipe to the tank. Be sure to use PVC cement and primer on all the joints and cement the new line into the tank. Do not push the new line to far into the tank as there may be a baffle in the tank.
John
johnjh2o is offline
Old 12-12-2012, 05:17 AM   #3
BasicPoke
Thanks John. What concerns me is that the pipe coming out of the slab is 4 1/2" diameter. The standard 4" PVC would be about 4", right? What type of cement should I use to seal to the septic tank? There is a cover in the tank near the inlet and I plan to install a PVC baffle. I believe the old one was concrete and is gone now.
BasicPoke
Quote:
John
Old 12-12-2012, 08:24 AM   #4
phishfood
Administrator
Liked 965 Times on 775 Posts
Likes Given: 1739
The outside of Schedule 40 PVC is just about 4 1/2".
I use hydraulic cement to seal to the tank, because I am impatient and don't want to wait for regular cement to dry. You have to work very fast and with small batches of that stuff, it sets up very quickly.
Lake County, Florida plumber
Springtime Plumbing Services
phishfood is offline
Old 12-15-2012, 04:02 AM   #5
BasicPoke
What would be the proper cement to connect the PVC to the septic tank? I mean exactly what is it called?
For a cleanout can I use just a standard 4" tee, like I have seen at Lowe's, or should I get one of those with more gentle curves?
What would be the ideal distance for a cleanout tee from the house, or should I worry about that?
Thanks
BasicPoke
Old 12-15-2012, 04:32 AM   #6
johnjh2o
johnjh2o's Avatar
Likes Given: 620
Use PVC regular cement with purple primer. For a cleanout you could use a clean out tee or a sanitary tee with a cleanout plug. I would put the cleanout were the line first exits the house.
John
johnjh2o is offline
Old 12-31-2012, 06:08 AM   #7
BasicPoke
Over the past several weeks, I have replaced the pipe, including a clean-out, added a baffle at the inlet, and replaced the effluent pump with a heftier one and different float configuration. One of the tougher decisions was how to seal the pipe to the concrete septic tank. I ended up using roofing asphalt (pretty much tar). The tar did not harden after a couple of weeks and I was reluctant to pile dirt on top of it. It all seems to be good now. See photos. My shovel and I are good friends now. Thanks for all the suggestions.
Old 12-31-2012, 06:27 AM   #8
KULTULZ
Jack of All Trades ~ Master of None
KULTULZ's Avatar
Liked 316 Times on 277 Posts
Likes Given: 172
NICE JOB!
But where does the sump pump come into it?
- PLUMBER'S GUIDE TO SUCCESS -
1) Hot On Left - Cold On Right
2) Shiat Flows Downhill
3) Lefty Loosey - Righty Tighty
4) Do Not Bite Nails
5) Plunge With Mouth Closed
6) Leave No DNA On Job Site
7) Just Say No To Plumber's Crack
8) Boss is PIA - His Wife Is Looker
9) Payday On FRI
10) There Is NO LH Monkey Wrench
KULTULZ is offline
Old 12-31-2012, 01:21 PM   #9
phishfood
Administrator
Likes Given: 1739
My guess is that the pump lifts the effluent (sewage out of the septic tank) up to an elevated drain field.
Nice looking job.
Old 12-31-2012, 01:26 PM   #10
johnjh2o
johnjh2o's Avatar
Likes Given: 620
Good job ,but I hope you used primer on those joints. I don't see any purple. Hopefully you used clear primer.
John
johnjh2o is offline
Roots in sewer pipe to main, Hydro-jet?? DavidN Drain and Sewer Cleaning 40 02-25-2013 10:19 PM
Replacing main supply line scruff General Plumbing Help 11 05-08-2012 08:05 PM
Need advice on main stack change...? vbtalent General Plumbing Help 2 04-17-2012 12:29 AM
replacing supply line from city's main mholmes General Plumbing Help 0 10-25-2011 06:54 PM
Best method for replacing a section of copper pipe (and a little advice)? tireshark General Plumbing Help 14 10-12-2011 06:43 PM
Newest Threads
