bathtub pop-up drain clogs
jojodwolf
Dec 7, 2012
20
I have a bathtub drain that has a pop-up stopper... and I need to clean the hair out to often... because of how it's set up you can't put any snakes or even simple hair grabbers through the grate... a bent hanger is what I use but not the best to really get all the hair... so what can I do to improve this?
Thanks
You need to go to a local big box hardware store and purchase the bathtub drain screen.
Do they sell plugs this size so that when the wife wants a bath I don't have to screw the metal plug back on.. ?
If the plug needs to be screwed in for a bath, you could always pick up a larger screen and invert it (making a dome) around the drain to catch all the hair. Women's hair and small drains have kept plumbers in business for many years.
Isn't that the truth. I can't even count how many plugged tubs I've augered full of hair
You should be able to find a old style rubber tub stopper at your local hardware store
bought a small screen insert... and by removing the screw from the old stopper that can be used when needed
I get this all the time from customers.. I've got a few old dental hooks and medical hemostats (like scissors but with teeth), 2 min and I'm done.
If all you take are showers the screen will work, after removing the hair. But I prefer using the drain as it's installed.
I bought one of those zip cleans.. but the metal grid in the drain does not let you pull the thing out without extreme force losing the hair on the way out
