Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Pumps and Wells > How to add well line to garage?
Thread Tools Display Modes
Old 11-27-2012, 02:43 PM   #1
saiphes
Likes Given: 1
Default How to add well line to garage?
Hello!
I'm trying to get an idea of what I need before I call a contractor.
I would like to add a line directly from the well to the garage because I think the project will be smaller than breaking through the cement slab and landscaping - especially as I have an excavator. We currently have the well line coming into an (Enviro Check -->), then to a manifold serving the pressure switch, pressure guage, pressure tank, and cutoff valve, and the rest of the system. The pressure switch has an electrical line which follows the water line back to the well.
I'm mostly concerned that the existing pressure switch will not know about the pressure to the garage.
What is the best way to Tee into the line at the well end (and run a 48" deep ditch up the driveway)?
I think I'd move the checkvalve to before the new Tee, and then either the pressure tank serves both the garage and the house, or I get a second pressure tank which will work in tandem.
Is this correct?
saiphes is offline
Old 11-27-2012, 04:14 PM   #2
Valveman
Pump Controls Tech
Valveman's Avatar
Liked 76 Times on 64 Posts
Likes Given: 1
You don't need another pressure tank. Just remove any check valves above ground and tee into the line anywhere you want.
www.cyclestopvalves.com
Valveman is offline
saiphes Likes This
Old 11-27-2012, 10:02 PM   #3
speedbump
Wells & pumps; not a...
speedbump's Avatar
Liked 211 Times on 192 Posts
Likes Given: 46
Quote:
(Enviro Check -->)
Are we talking about an anti siphon valve here?
I agree with Cary, just tee in and get rid of any above ground check valves and don't add any more.
speedbump is offline
Garage Retreat Chris General Discussion 9 05-25-2012 04:17 PM
Drain line in garage for Laundry will not clear up and overflows sel4ever15 Drain and Sewer Cleaning 7 05-25-2011 06:20 AM
Need help to run water in my detached garage AlainTernet General Plumbing Help 2 10-04-2010 09:12 PM
Need to add faucet in garage beast696 General Plumbing Help 6 08-13-2010 11:05 PM
Drain pit in the garage dry? memorex88 Drain and Sewer Cleaning 2 02-19-2010 03:38 PM
Newest Threads
