Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > PEX for plumbing compressed air?
Thread Tools Display Modes
Old 11-14-2012, 12:33 PM   #1
Otahyoni
Established Member
Otahyoni's Avatar
Liked 13 Times on 11 Posts
Likes Given: 1
Default PEX for plumbing compressed air?
So i have been tasked with plumbing up an air system in our new building from scratch and wondering what my options are.
Ones I can think of are:
Copper (too expensive)
Galvanized steel pipe (maybe)
DOT air line (line isn't bad but fittings are pricey)
PEX (?)
PVC (i know...it could explode and kill me....)
This is a very large building (80'x120') so it's important to be cost efficient. What would be my best option?
Also this is primarily an equipment shed that will be used some of the time for servicing the equipment, so how should i lay out the the outlets?
~The Amish Wolfman
I am known by many names:
Otahyoni, Otah, Utah, Chris, Steve, Fred, The Amish Wolfman, and Mark's Little Buddy... :D
Otahyoni is offline
Old 11-15-2012, 12:18 AM   #2
Otahyoni
Established Member
Otahyoni's Avatar
Likes Given: 1
37 views and no one knows?
~The Amish Wolfman
Otahyoni is offline
Old 11-15-2012, 12:53 AM   #3
phishfood
Administrator
Liked 964 Times on 775 Posts
Likes Given: 1739
The standard in the industry for airlines is steel pipe, and galvanized would be better for this application. It can be labor intensive, but once you get a rhythm going it isn't to bad.
I kinda think PEX is a viable option, but I have never heard of it being used for airline. If you decide to go that route, make very sure it can't rub against metal and wear a hole through it.
Lake County, Florida plumber
Springtime Plumbing Services
phishfood is offline
Old 11-15-2012, 02:23 AM   #4
stevemachine
stevemachine's Avatar
Liked 115 Times on 99 Posts
Likes Given: 97
I've never used pex but agreed with phish. I would probably use pex for cost effectiveness and ease of install, but yeah protect that pex for anything sharp. I think it would work fine but I've never used it for compressed air, usually copper. But copper would take days upon days
stevemachine is offline
Newest Threads
