Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Toilets and Sinks > Toilet flush - plastic ball not rising
Thread Tools Display Modes
Old 03-21-2010, 11:24 PM   #1
sanbeach1
Default Toilet flush - plastic ball not rising
Usually when you flush, the toilet will automatically refill the water in the tank and automatically stop when the blue plastic ball rises to the top. However, now the blue plastic ball won't rise to the top properly and so it keeps on refilling the water. It doesn't overflow, but it's very noisy and wastes water. For now, I'm using a piece of tape to hold up the ball up once the tank has refilled, but I have to undo the tape each time i flush so the tank can refill the water.
Please help - does anyone have any advise??? Thank you!!
sanbeach1 is offline
Old 03-22-2010, 12:04 AM   #2
phishfood
Administrator
Liked 965 Times on 775 Posts
Likes Given: 1739
Replacing the ballcock assembly should remedy the problem. We had a thread on this a little while ago, I'll see if I can find it.
Found it: http://www.plumbingforums.com/forum/...flow-pipe-330/
phishfood is offline
Old 03-22-2010, 01:00 PM   #3
majakdragon
The old arm and ball floats are a bad part of plumbing history. The arms bend, the balls crack or hang up on the side of the tank. Replace the unit with a Fluidmaster 400A fill valve (for under $10) and you will be done with the problem. The instructions included are very easy to read and understand.
If you have never made a mistake, you probably haven't done much.
majakdragon is offline
Old 03-22-2010, 01:17 PM   #4
Mr_David
Easily Amused
Mr_David's Avatar
Liked 895 Times on 726 Posts
Likes Given: 593
I agree. Make sure you use the clip that comes with it to attach the refill tube to the overflow. If you stick it into the overflow like the original it can siphon water out of the tank.
crazy-bad-toilet-fill-valve
a.k.a. Krazedav
Mr_David is offline
Old 04-24-2010, 01:48 PM   #5
PlumbingTheCape
replace the float valve. Or get hold of a plumber
Darren Bosman
-Master Plumber-
www.plumbingthecape.co.za
PlumbingTheCape is offline
Tags
tank flush ball refill
Toilet Flange Flush or Above Finished Floor? Bogucki General Plumbing Help 6 07-03-2012 01:27 AM
Toilet flush problems..........GRR! smitty81 Toilets and Sinks 6 04-29-2012 01:07 AM
Low Water Pressure/Toilet Won't Flush brandonkbrock General Plumbing Help 3 09-13-2011 01:49 AM
Toilet Bowl Water Level Alternates Level and Flush leichte Toilets and Sinks 2 09-15-2010 02:00 PM
ToTo Toilet - Will it Flush Video - By John C Flood JohnCFlood Toilets and Sinks 5 07-28-2010 06:57 PM
Newest Threads
