Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Water Heaters and Softeners > 3 full baths-hot water heater
Thread Tools Display Modes
Old 10-28-2012, 01:20 PM   #1
dolfans
Default 3 full baths-hot water heater
We are househunting and have some questions about hot water heaters. A house we are planning to look at has 3 full bathrooms. Would/should there be more that 1 hot water heater? thanks
dolfans is offline
Old 10-28-2012, 02:30 PM   #2
stevemachine
stevemachine's Avatar
Liked 115 Times on 99 Posts
Likes Given: 97
It's really based on amount of people, if you have 4 people, a 40 gal is fine. But if you have more than that you will want a 50 gal. Depends a lot on usage. I would say an average shower for the average person probably uses 10 gallons of hot water, as long as it isn't a rain shower head.
stevemachine is offline
Old 10-28-2012, 02:46 PM   #3
dolfans
There are 6 of us 2 adults,teen girl,3 kids 8,6,4 and teen girl is in the shower most of time for 30 mins to an hr or seems like it
dolfans is offline
Old 10-28-2012, 03:15 PM   #4
stevemachine
Likes Given: 97
Ah ok well then yeah you may want to consider either another water heater, or a bigger one. Also tankless might be a good option for you depending on what you're willing to spend. Tankless is nice cause its unlimited hot water, however they do require maintenance, and a water softener, if your water has any hardness at all. The tankless are quite efficient too, so they'll pay themselves off in the long run. Call out ideally 3 plumbers and get quotes to do the work, whether you want that extra tank/bigger tank or a tankless water heater
Old 10-29-2012, 02:43 AM   #5
Beni
Liked 15 Times on 14 Posts
I might shy away from tankless type. Oh they work fine. But with one teen and 3 future teens, having unlimited hot water is not always a good thing. Think high gas bills..
If you have a gas water heater 40 gallons will be a tad small, but as long as you don't have too many people showering at the same time it should be fine. A 50 gallon gas water heater would be a good choice. Not too small and not too big..
With electric I might push for 60 gallons or so. Electrics only recover 18 gallons an hour. So after the teen takes the typical long shower you'll be waiting 2-3 hours for the next showers. Gas recovery varies from 30 ish to 45 ish GPH.
Beni is offline
Old 10-29-2012, 04:57 AM   #6
IFIXH20
HERE TO HELP
Liked 236 Times on 187 Posts
Likes Given: 165
Most standard 3 bath homes has a min. 50 gal. water heater . If the master bath has a large Garden,roman,jacuzzi tub Then you would want more than 50 gallons with a electric water heater -- If you have gas , you want a 50/50 water heater ( meaning 50 gal- 50000 btu's) with 3 baths.
IFIXH20 is offline
Old 10-30-2012, 11:40 PM   #7
Beni
Quote:
Good catch on the larger bath tubs. A nice roman or jucuzzi tub if it is say 72 inches x 32 inches will need at least an 80 gallon and I sometimes spec 100 gallons as that gives a bit of safety factor if the dishwasher, etc is running at about the same time the tub is being filled.
Same goes for the newer multi-head showers too....
Beni is offline
Old 11-07-2012, 11:36 PM   #8
dolfans
The house has 2 regular tubs and the master bed room bath is a shower only. The house is something like 2600 sq ft. but laid out strange. The house is a barn type house 3 floors(2 baths and water heater etc) then the kitchen is in the middle and a cabin on the side with 1 full bath. Not sure but i don't think there is a water heater under the cabin. Will look with the inspection. thanks
dolfans is offline
blocked sink drain-back2back 2nd story baths dianedebuda Drain and Sewer Cleaning 6 11-04-2012 11:03 PM
Full pressure, no hot water in shower ucsbgaucho General Plumbing Help 2 07-18-2012 11:14 PM
Converting 1/2 bath to full with shower FordPrefect4 Showers and Tubs 0 05-06-2012 10:33 PM
Shower water runs full blast with (Delta) cartridge installed or not chirpie Showers and Tubs 12 12-13-2011 01:26 AM
mysterious tub full of clear (slightly blue) water anemrac Showers and Tubs 2 09-05-2011 12:18 AM
Newest Threads
