Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Replacing cartridge in single handle faucet
Thread Tools Display Modes
Old 10-11-2012, 04:46 PM   #1
Windy
Liked 19 Times on 18 Posts
Likes Given: 24
Default Replacing cartridge in single handle faucet
Okay, I have done this many times before but the last time I tried to do it I failed miserably and had to call a plumber. I know this is simple but last time I could NOT pull that darned cartridge out of the pipe after I took the handle off. I know to remove that retaining pin 'thingy' and grab a bit of the cartridge and pull it out. It would not come out. I ended up putting it all back together and calling a plumber, who also had a heck of a time getting it out.
So, now my bathtub faucet has a drip again and I want to replace that cartridge. Oh, let me say it's an older single handled Moen bathtub faucet. Is there any special tools I need that I didn't have last time that might make this go easier? What I do is use a screwdriver to remove the handle then I use pliers to grab a bit of the old cartridge and try to pull it straight out. Is there anything I should know here that I am missing.
Also, I have bought a generic cartridge. Would I be best served to return that and buy an actual Moen brand cartridge?
I would appreciate any suggestions or ideas. I want this to go as smooth as possible and I am going into this very simple project with a little trepidation.
I am 'older' and a 'girl' so home repair projects are not my forte, really. But I do what I can.
Windy is offline
Old 10-11-2012, 06:12 PM   #2
stevemachine
stevemachine's Avatar
Liked 115 Times on 99 Posts
Likes Given: 97
They make cartridge pullers for moen, the old ones I've done I used the tool that came with the cartridge. The worst one I had, I had to put a long screw into the brass stem, put a 2x4 on the wall and use pry bar. But I'd try a cartridge puller tool first, big box stores may have them or plumbing wholesalers should have them
stevemachine is offline
Old 10-11-2012, 08:44 PM   #3
johnjh2o
johnjh2o's Avatar
Liked 726 Times on 550 Posts
Likes Given: 620
Just to add to steve's post. Return the cartridge and call Moen's 800# and they will send you the correct cartridge free of charge.
John
johnjh2o is offline
Old 10-11-2012, 09:30 PM   #4
reedplumber
reedplumber's Avatar
Liked 1 Times on 1 Posts
This is the moen cartridge puller I use, works great
reedplumber is offline
Old 10-11-2012, 10:49 PM   #5
Windy
Likes Given: 24
Quote:
John
Seriously? Those things are kind of pricey at the stores. I don't know the model number of my Moen faucet. Like I said, it is old and it was there when I bought this house over 20 years ago. I have an old one I kept that I carry to the store with me when I need to buy a new one. I will call the #800, though. That would be incredibly awesome if I could get one for free.
Quote:
Originally Posted by reedplumber View Post
Attachment 2930
Well, I'll be darned. I had no idea they made a tool for that. Do you have any idea what they cost? I think I will have to get one of those. I believe what makes my self repair projects difficult is I don't have the right tools to get the job done. If you don't have the right tools, you are at a disadvantage.
Thank you for all replies. Any other suggestions? I'm listening.........
Windy is offline
Old 10-12-2012, 01:55 AM   #6
reedplumber
There's two types of pullers for moen depending on your cartridge that one is less than 20 the other is around 35 either way it's a great investment, good luck in the future
Old 10-12-2012, 03:26 PM   #7
journeyman
the professional
journeyman's Avatar
Liked 150 Times on 117 Posts
Likes Given: 150
moen cartridges have a life timew warranty take cartridge to a fergusons and they will give you a new cartridge for free.
journeyman is offline
Old 10-12-2012, 04:29 PM   #8
Windy
Likes Given: 24
John
Quote:
I called both places and neither will give me a free cartridge. I tried.
Maybe that offer is just for plumbers?
Windy is offline
Old 10-12-2012, 05:25 PM   #9
johnjh2o
johnjh2o's Avatar
Likes Given: 620
Windy here is Moen's site with there warranty. Hope this helps.
http://www.moen.com/consumer-support/warranty
john
johnjh2o is offline
Old 10-13-2012, 02:37 AM   #10
Windy
Likes Given: 24
Thank you. I'll call again armed with that info.
Windy is offline
Delta shower single handle faucet help scrabbler Showers and Tubs 1 08-14-2012 03:42 PM
single handle one hole antique faucet mtbe General Plumbing Help 4 10-18-2011 12:54 PM
Delta single-handle faucet leaks from housing. ericblair General Plumbing Help 1 04-17-2011 05:19 PM
Moen single handle shower faucet rough in Dogstar General Plumbing Help 3 03-05-2011 01:10 AM
Low pressure caused by single handle faucet? RAM1961 General Plumbing Help 2 04-27-2010 12:09 PM
Newest Threads
