Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Toilets and Sinks > Toilet leak coming through ceiling?
Thread Tools Display Modes
Old 03-15-2010, 03:23 PM   #1
jbrianchamberlin
Default Toilet leak coming through ceiling?
I'm in desperate need of some help. I apologize in advance for my lack of vocabulary but I'll do my best. I'm remodeling my kitchen and after painting the ceiling, I notice a spot that wouldn't seem to dry. It's right below a bathroom upstairs, specifically the toilet.
I removed the old toilet which was very lose. It roacked back and forth pretty easily. The wax was terribly old and the flange was cracked. The flange was installed above ceramic tile and the tile around it was all cracked. I put one of those flange savers over the old flange and used white silicone on all the cracks and around the flange. I reinstalled the toilet with a new wax ring but it no longer sits flush. I'm not sure if this repair fixed the water problem below. I imagine it will take some time to dry... might have to replace that portion of the ceiling. I guess my question is this... should I remove the toilet again, cut out the old flange and install a new one? I guess I'd have to replace tile around it as well but this might be a better long time sollution.
jbrianchamberlin is offline
Old 03-15-2010, 04:08 PM   #2
havasu
Administrator
havasu's Avatar
Liked 524 Times on 432 Posts
Likes Given: 80
You don't want to deal with future water damage. Remove your toilet and check to see if your flange repair is installed correct and level. Once this is done, replace your wax gasket and avoid caulking this seam until you are certain you have no more leakage. I've also heard many plumbers double up on the wax gaskets as a form of leak insurance, but will take time to settle and seal correctly.
If it is your intention of cutting the downstairs ceiling in order to repair the damage, you could place a few newspapers in the opening for a few days, and check it often for any signs of leakage before you patch and repaint it.
If you are uncertain if your flange is correctly installed or need a replacement flange, this is when I would call in a professional.
havasu is offline
Old 03-16-2010, 01:51 AM   #3
phishfood
Liked 513 Times on 413 Posts
Likes Given: 682
The chances are that you would have to cut out the ceiling to replace the flange. IF YOU DO NOT, AND LEAVE THE TOILET RAISED UP FROM THE FLOOR, MAKE CERTAING TO SHIM THE TOILET WITH PLASTIC SHIMS. Not doing so will allow the toilet to continue rocking and cause another leak. In fact, improperly/unshimmed toilets are probably one of the biggest causes of broken flanges.
phishfood is online now
Old 03-16-2010, 01:02 PM   #4
majakdragon
If the flange is cracked, it is also possible that the rocking also broke or cracked the pipe below it. Save time and money by doing an inspection of both the pipe and the flange before completing the job and finding out later that you must start all over.
If you have never made a mistake, you probably haven't done much.
majakdragon is offline
Old 04-05-2010, 11:55 PM   #5
jimclemmer
Hey
Your flange is cracked it is very risky it will cracked the pipe below, so i suggest you would have to cut out the ceiling to replace the flange.
Thanks
Regards
Ambani
Hot Water Heater Replacement
jimclemmer is offline
Old 04-24-2010, 01:38 PM   #6
PlumbingTheCape
call a plumber...
Darren Bosman
-Master Plumber-
www.plumbingthecape.co.za
PlumbingTheCape is offline
Old 03-20-2011, 09:52 PM   #7
westflo
I think the first thing you should do is to fix the water damage first. Because t can lead to growing of molds that is really harmful to human's health as well as to your home. It is much dangerous because the water might came from the toilet.
westflo is offline
Tags
leaking, toilet, cracked flange
Leak from toilet shutoff valve Kissimmee General Plumbing Help 3 04-01-2014 11:15 PM
need help detecting the source of a bathroom ceiling leak starfish11040 Showers and Tubs 3 10-24-2011 04:13 AM
Leak around pipe coming from street GaryTarr General Plumbing Help 4 10-04-2011 03:44 AM
Leak from ceiling right below toilet michaelemery Toilets and Sinks 1 03-29-2011 03:21 AM
How to stop a Drain Leak in the ceiling? slavav50 Drain and Sewer Cleaning 9 10-08-2010 01:09 AM
