Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Toilets and Sinks > My toilet spits?
Thread Tools Display Modes
Old 03-15-2010, 03:15 PM   #1
Chris
Administrator
Chris's Avatar
Liked 538 Times on 474 Posts
Likes Given: 45
Default My toilet spits?
Is there any logical reason why my toilet spits on my ankles? When I flush the toilet it will spit out a drop or two of water and for some reason it always hits me no matter how much I jump around. I am getting pretty disgusted with this and want to fix it, is there anything I can do besides replace the toilet?
Chris is offline
Old 03-15-2010, 03:50 PM   #2
havasu
havasu's Avatar
Liked 499 Times on 415 Posts
Likes Given: 71
Either you need a new wax gasket assembly around the base of your toilet, or change your food choices.
havasu is offline
Old 03-15-2010, 06:55 PM   #3
PlumbingAdmin
Administrator
PlumbingAdmin's Avatar
Liked 90 Times on 84 Posts
Likes Given: 224
Quote:
That's pretty disgusting.
PlumbingAdmin is offline
Old 03-15-2010, 11:58 PM   #4
havasu
havasu's Avatar
Likes Given: 71
If you have to jump around alot, I'd also have a doctor check you for STD's!
havasu is offline
Old 03-16-2010, 03:17 AM   #5
Chris
Administrator
Chris's Avatar
Likes Given: 45
Quote:
What would tha wax ring have to do with this? It spits out of the bowl not from under the toilet.
Quote:
Tell me about it! I am the one getting spit on.
Hmmm... an STD? Scrambling fromToilet Disorder?
Chris is offline
Old 03-16-2010, 04:49 AM   #6
havasu
havasu's Avatar
Likes Given: 71
I apologize for my assumption. I'd just spend a few bucks and purchase a new toilet. Is it old?
havasu is offline
Old 03-16-2010, 12:58 PM   #7
majakdragon
Use a mirror and check the holes under the rim that allow the water from the tank to the bowl. Sometimes mineral deposits can hang up there and cause a "lip" that catches water and redirects it to places other than the bottom of the bowl.
If you have never made a mistake, you probably haven't done much.
majakdragon is offline
Old 03-16-2010, 04:03 PM   #8
Chris
Administrator
Chris's Avatar
Likes Given: 45
The house was built in 97 so I assume it is the original.
Quote:
Checked and they are clean, I think it is happening when I flush and the rush of water hits the standing water in the bowl and it causes a splash. Looks like I will finally go grab a new toilet.
Chris is offline
Old 03-19-2010, 10:20 PM   #9
Mr_David
Easily Amused
Mr_David's Avatar
Liked 31 Times on 23 Posts
Likes Given: 4
Wow! You seem to be having all sorts of plumbing issues.
Good thing you have skills and don't have to hire a plumber.
Do you have a standard type of toilet with a flapper or is it one with a pressurized tank. The pressurized ones have a tendency to splash.
Buy American Made if you get a new one.
Kohler is what we usually put in.
Mr_David is offline
Old 04-24-2010, 01:46 PM   #10
PlumbingTheCape
could you post some pictures of the toilet?
Darren Bosman
-Master Plumber-
www.plumbingthecape.co.za
PlumbingTheCape is offline
Tags
toilet, spit, water
Newest Threads
