Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Drain and Sewer Cleaning > backflow, vent pipe collapsed...
Thread Tools Display Modes
Old 09-18-2012, 03:12 AM   #1
tiatia
Default backflow, vent pipe collapsed...
Hi, I am having several plumbing issues which may or may not be related. I leased a restaurant recently, the building was built in 1974, and has seen a lot of grease in it's days. Anyways, the toilet started backing up so I had a plumber come out he ended up snaking, jetting, and putting a camera through the lines. He said I had a break and needed to replace the cast iron. Had a second plumber come out they sent a camera down and said they didn't see any breaks but I should empty my grease traps, and jet the back lines which I did.
Toilet issue was fixed so I opened the restaurant. Now there is a horrible smell if I drain my kitchen sinks. Also the mop sink never completely drains. The floor drain behind the bar which has about an inch of 2.5 pvc pipe sticking out of it (so not really a floor drain I'm assuming) overflows if I drain a sink fully and then begins to overflow in a similar floor drain in the kitchen. I ended up tearing out some damaged tile in the restroom and found rotting drywall so after tearing that out I saw what looks to be a vent pipe completely crumbled.
So many problems! And unfortunately no more money left to throw at all of them without (hopefully) a fix... any thoughts?
tiatia is offline
Old 09-18-2012, 03:27 AM   #2
johnjh2o
johnjh2o's Avatar
Liked 437 Times on 344 Posts
Likes Given: 278
The first plumber may have been right. If it's piped with no- hub cast iron the lines may be failing. No-hub cast iron in a restaurant will break down. Do you have a basement or are you on a slab?
John
johnjh2o is online now
Old 09-18-2012, 05:07 PM   #3
AQualityPlumber
Plumber
AQualityPlumber's Avatar
Liked 13 Times on 11 Posts
Sounds like you need to replace the sewer system in the ground. Don't be cheap about it. If this was anything other than a restaurant, I would say fix the little stuff. However, you are serving the community a prepared consumable product. Your sewer system failing in that extent is probably at the end of its life expectancy. It is considered a dangerous hazard and you will have more and more problems with it. Based on these facts my professional recommendation is to at least replace the groundwork in the slab. Serving the public food is the most dangerous environment when sewer fluids and gasses leak. Find a licensed and bonded plumbing contractor immediately to get an estimate. Oh ya, do not serve food until this issue is resolved.
A Quality Plumber Inc.
www.PlumbingWA.com
www.plumbingwa.blogspot.com
AQualityPlumber is offline
Old 09-18-2012, 06:45 PM   #4
tiatia
John, its slab no basement.
AQUALITYPLUMBER, what do you mean by sewer system, what does that all entail? The gas station across the street sometimes has a sewer smell, could there possibly be something wrong with the city's system as well?
btw there is cast iron until the middle of the parking lot when it becomes plastic until it meets up with the city's system across the street. does that mean half of the piping was replaced to plastic?
Thanks
tiatia is offline
Old 09-18-2012, 06:53 PM   #5
tiatia
Also, obviously there is a bigger problem but could the smell be from no ventilation? It doesn't come from the kitchen it seems to be coming from an entryway off the front of the building. We used the sinks before discovering all these problems and never had a stinky problem. the second plumbers who came out opened up a cleanout near the front door that also never had a smell which would have been extremely noticable but after having it opened and resealed definitly lets out an odor. we worked on the building for about 2 months (using sinks, flushing toilets) before these problems arose. Just some more info
tiatia is offline
Old 09-18-2012, 07:07 PM   #6
johnjh2o
johnjh2o's Avatar
Likes Given: 278
The only real way find out what is going on before breaking up the floor would be to get the lines cameraed. That will tell you if the line or lines needs to be replaced.
John
Old 09-18-2012, 10:00 PM   #7
AQualityPlumber
Plumber
If a sewer system is installed correctly you should not smell any gases. You may consider a smoke test if you can't find the leak.
www.PlumbingWA.com
Old 09-18-2012, 10:41 PM   #8
johnjh2o
johnjh2o's Avatar
Likes Given: 278
Quote:
I don't think it's a question if it was installed correctly or not it's a question of if he has any broken lines.
John
Old 09-19-2012, 12:20 AM   #9
tiatia
Quote:
John
I had the lines camera'd twice. I couldn't see or tell if there was a break and I just got two conflicting responses for either plumber. (she btw)
tiatia is offline
Old 09-19-2012, 12:40 AM   #10
IFIXH20
HERE TO HELP
Liked 215 Times on 171 Posts
Likes Given: 150
Did the plumbers offer you a video of the drain that was camera -- Can you post some photos of the crumbled pipe. The cleanout cap may need some pipe dope to seal it.
IFIXH20 is offline
Studor vent on vent pipe above roof gquayle General Plumbing Help 4 09-13-2012 02:23 PM
How do I cut attic vent PVC pipe? mtv General Plumbing Help 2 11-19-2011 05:04 PM
cutting vent pipe mijoda52 Showers and Tubs 3 10-09-2011 09:05 PM
Vent Pipe Configuration Centuriondk General Plumbing Help 13 06-05-2011 06:44 PM
Poorly placed vent pipe cookingterm General Plumbing Help 4 03-05-2010 11:16 PM
