Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Cast Iron Waste Line Help Needed!
Thread Tools Display Modes
Old 09-10-2012, 11:43 PM   #1
handymanmac
Default Cast Iron Waste Line Help Needed!
I need advice for the below picture. The waste line plugged up and the clog couldn't be cleared. So I am now gutting the bathroom. (The house is from 1915 but we were told it was remodeled in 1948.) The sink and toilet lines are galvanized and the main line is cast iron. Above the "T" in the vent line for the sink, plain 2" steel was used. It completely rotted away and filled the line with debris. My question is can I snap the cast iron at the elbow where it comes out of the wall and transition to PVC with a Fernco? The main line was scoped and it was in good shape. If I snap the cast iron i wont have to destroy the old plaster walls to try and repair the toilet and sink lines.
Thanks in advance for the help.
handymanmac is offline
Old 09-11-2012, 12:09 AM   #2
johnjh2o
johnjh2o's Avatar
Liked 696 Times on 529 Posts
Likes Given: 582
The best way would be to cut the 4" cast iron behind the hub and re-pipe from there. That lead bend will be the next thing to go. Use a banded coupling on the 4" to convert to PVC. Can't see what you have in the wall but that can also be cut and using a banded coupling that to can become PVC. What is the open 2 x 1-1/2" tee for? Here is a link to banded couplings. They are far better then rubber fernco.
http://www.fernco.com/plumbing/shiel...flex-couplings
John
johnjh2o is offline
Old 09-11-2012, 12:58 PM   #3
handymanmac
The open tee was where the bathtub drain connected.
Old 09-11-2012, 01:03 PM   #4
johnjh2o
johnjh2o's Avatar
Likes Given: 582
If you change it all, as you should do then that will become PVC also. I think space will become your biggest problem. You can reduce the line to 3" which will help. Just put a 4 x 3" flush bushing into the 4" banded coupling.
John
johnjh2o is offline
Old 09-11-2012, 02:09 PM   #5
handymanmac
Will do. Thanks for the help.
Old 09-11-2012, 03:20 PM   #6
rednip1203
Jason Pinder
rednip1203's Avatar
Wow USA plumbing looks complicated!! This is how we do it in the uk. All PVC to a 4" stack
rednip1203 is offline
removal of cast iron tub bggas400 General Plumbing Help 13 02-20-2014 01:13 PM
Cast iron vs Steel Tub? Spud Showers and Tubs 7 01-07-2012 11:20 AM
Need help with cast iron please coppens77 Drain and Sewer Cleaning 3 12-13-2011 01:14 PM
Cast iron info needed oakumboakum General Plumbing Help 1 09-06-2011 12:18 PM
Cast out the cast iron? Bodrey General Plumbing Help 4 01-14-2011 03:36 PM
Newest Threads
