Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Pumps and Wells > Banging pipes when well pump kicks on
Thread Tools Display Modes
Old 07-28-2012, 05:51 PM   #1
wingnut225
Default Banging pipes when well pump kicks on
Hi,
I have a well pump and whenever the pump kicks on, the water supply line (PVC) in the basement that leads from outside to the tank will make a loud bang noise. This occurs at a 90 in the line. I thought it might be air in the line as if the foot valve at the well pump is bad but I don't get any air come out when I turn on the faucets. I have researched "water hammer" but that mostly refers to when a faucet is turned off. How do I remedy this? Most annoying plus I don't want my PVC water line break.
Thanks!
Chuck
wingnut225 is offline
Old 07-28-2012, 08:11 PM   #2
spyshot
Established Member
check valve?
spyshot is offline
Old 07-29-2012, 12:52 PM   #3
orlandosterilizer
I have encountered this before (im a state certified florida master plumber of ten years) and the remedy is usually to place the bladder or hydro-pneumatic tank directly adjacent to the supply well pump with as little turns in the the pipe as possible. Doing this will give lots of expansion for in incoming rush of water wich exerts many pounds of force in the pipe fittings leading to failure.
orlandosterilizer is offline
Old 07-29-2012, 06:05 PM   #4
speedbump
Wells & pumps; not a...
speedbump's Avatar
Liked 168 Times on 153 Posts
Likes Given: 42
What kind of pump do you have? A submersible or a jet?
speedbump is offline
Old 07-29-2012, 08:25 PM   #5
Valveman
Pump Controls Tech
Valveman's Avatar
Liked 57 Times on 46 Posts
Likes Given: 1
Remove any check valves above ground. The “foot valve” is the only check valve you need in the system. Then if as you suspect the foot valve is bad, the pressure will drop and the pump will start up even though you are not using any water in the house or yard. The above ground check valve is masking the problem at the moment, but it is also causing the water hammer on pump start. Replacing the foot valve is usually the only way to solve this problem.
www.cyclestopvalves.com
Valveman is offline
Old 07-30-2012, 12:58 PM   #6
speedbump
speedbump's Avatar
Likes Given: 42
This made me wonder just what the heck was going on, so I'm trying to figure out if you have a sub or a jet. Foot Valves are not at the pump. They are in the well. Some people think submersible pumps have Foot Valves.
Old 10-25-2012, 09:02 AM   #7
teganiqbal
Banned
We have a well, not public water. Several seconds when the regulator tells the well pump to kick on, our water pipes bang. What are the causes for this banging and how can it be stopped?
teganiqbal is offline
Old 10-25-2012, 01:05 PM   #8
speedbump
speedbump's Avatar
Likes Given: 42
Like mentioned above. Remove any above ground check valves.
Old 04-30-2014, 03:51 PM   #9
wingnut225
It's been a while but I wanted to post the fix in case anyone in the future has the same issue.
I had a plumber check the well and indeed, the check valve or foot valve was bad. Strangely enough, I wasn't getting any air come out when I would turn on the faucets. Since he had the 17 year old pump out of the well, I had him replace the well pump along with the check valve. It's been almost two years now and all is good. No more banging of the pipes!
I appreciate all of your thoughts and comments!
Chuck
Old 05-01-2014, 12:51 PM   #10
Valveman
Pump Controls Tech
Valveman's Avatar
Likes Given: 1
Thanks for the update. The check valve at the bottom of the well must be fixed or replaced to stop this kind of water hammer. Sometimes just removing the above ground check valve makes the bottom check work and solve the problem. In many states an above ground check valve is illegal, as it can potentially draw contamination into the well. Other states have not figured that out.
In Texas they say you must have a check valve above ground, but you cannot cause a negative pressure on the underground line. This just shows how little our government officials understand about their jobs. An above ground check valve CAUSES negative pressure on the underground line. So you can’t have it both ways.
Most people just put a second check valve as a “safety” for when the bottom check fails. What they should be doing is eliminating the pump cycling, which is what causes check valves to fail. Glad you got it fixed, but if you still have an above ground check valve and your pump is still cycling on/off repeatedly, you will soon have the problem again.
Valveman is offline
Banging pipes: air or pressure regulator or ? Chart General Plumbing Help 20 03-15-2013 12:07 AM
Banging Faucet - Well heenan79 Pumps and Wells 2 12-01-2011 09:46 PM
Sudden pressure drop before pump kicks in mikenh General Plumbing Help 4 01-04-2011 09:43 PM
2 banging pipes chadliljedahl General Plumbing Help 2 05-11-2010 05:07 PM
water pipes banging stanny General Plumbing Help 1 05-01-2010 04:26 AM
Newest Threads
