Plumbing Forum - Professional & DIY Plumbing Forum > General Discussion > General Discussion > Cutting out wall studs
Thread Tools Display Modes
Old 03-02-2010, 04:53 PM   #1
PipePig101
PipePig101's Avatar
Default Cutting out wall studs
Has anyone got a clean way to cut out wall studs w/o ruining or disturbing the other side of a wall? The drywall screws are tough to deal with but nails cut reasonably well.
I used a Multi-Tool with a saw blade to get under the studs and dead-end cut them to the drywall (Harbor Freight $39) but the blade would not cut the hard-dry wall screws. I had to use a $30 flush cut/carbide disc on a Roto Zip to cut them. There was a lot of wood burning going on that day...
PipePig101 is offline
Old 03-02-2010, 05:59 PM   #2
havasu
Administrator
havasu's Avatar
Liked 1114 Times on 906 Posts
Likes Given: 334
I've always used a sawzall for light demo but one question I have is..."What is going to hold up the drywall if you remove the studs?"
havasu is offline
Tags
Multi-Tool, wall studs, Roto Zip
Cutting Plastic Pipe blitz Plumbing Tools and Equipment 21 06-01-2012 03:27 PM
First Post - Running piping through studs myethreesuns General Plumbing Help 2 12-13-2011 09:49 PM
Cutting and Soldering pipes help Kshelley41 General Plumbing Help 10 11-24-2011 03:36 AM
cutting a flexible coupling bob_d General Plumbing Help 1 11-18-2011 01:20 PM
cutting vent pipe mijoda52 Showers and Tubs 3 10-09-2011 09:05 PM
Newest Threads
