Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Toilets and Sinks > Shower into toilet drain
Thread Tools Display Modes
Old 07-10-2012, 03:08 AM   #1
FLGSHP7
Default Shower into toilet drain
Hello,
This my first post so hi all! For starters I have no plumbing experience.
My question involves using a toilet drain for a shower drain on a concrete floor.
I really have no other place to put a shower in this building and need to figure out a way I can safely do this. I suppose I will have to bust up the concrete around the toilet drain, put in traps, and then recement around the the shower drain I have created? Any help is much appreciated. Also, the shower will be completely tiled to the floor.
FLGSHP7 is offline
Old 07-10-2012, 11:41 AM   #2
johnjh2o
johnjh2o's Avatar
Liked 726 Times on 550 Posts
Likes Given: 620
It's a little more involved then that. If it's going to have a tiled floor then you need to install a shower pan. If you don't know what a shower pan is then I suggest you call a plumbing contractor.
John
johnjh2o is offline
Old 07-10-2012, 12:50 PM   #3
FLGSHP7
I understand the shower pan, membrane, etc....my question is only regarding the shower drain into a toilet drain....as of now anyway. I am basically wondering how I should go about adding a trap below grade. The floor is tiled over concrete. I suppose I will have to cut all the way through the concrete, plumb down to 2", add a P trap and then re-cement the hole I've made. Also, as far as I'm aware, if if I was to re-cement all my piping would have to be cast iron?
FLGSHP7 is offline
Old 07-12-2012, 10:13 PM   #4
FLGSHP7
Bump. Help? Anyone?
FLGSHP7 is offline
Old 07-13-2012, 04:54 AM   #5
LiQuId
Liked 15 Times on 11 Posts
Likes Given: 20
you would need a vent on the line to properly be installed and sufficiant to vent the Wc. and shower. and your pipe wouldnt need to be cast iron. I suspect that you would be better off hiring a contractor.
LiQuId is offline
Old 10-15-2012, 06:21 PM   #6
rquad
All drain lines go to the same place. Go ahead and tap into the toilet just like you've said. As another poster suggested, make sure you have proper venting in the new line--you can use a Studor vent for this, installed in the walls if needed. Make sure you get the proper glue for your PVC connections, and make sure you follow the directions EXACTLY for gluing so you don't have any leaks. Other than that, go for it. I've saved thousands over the last few years by doing things myself--even things that seemed formidable at first. You learn by doing, and by getting yourself into and out of trouble. Ask people at your nearest big-box home improvement store for help--they can tell you a lot, and most of the time it's right.
rquad is offline
Old 10-16-2012, 12:39 AM   #7
phishfood
Administrator
Liked 965 Times on 775 Posts
Likes Given: 1739
Do NOT put a studor vent/ air admittance valve inside of a wall, unless you also install an access panel.
Just my personal professional opinion, but I shy away from AAV's whenever possible. They are a check valve, so they can't relieve positive pressure in the plumbing system, only negative pressure. Also, they are a mechanical device, which means that they can and do fail.
Lake County, Florida plumber
Springtime Plumbing Services
phishfood is offline
Old 10-16-2012, 01:57 AM   #8
PioneerPlumber
:0)
PioneerPlumber's Avatar
Liked 21 Times on 21 Posts
Likes Given: 5
Are you going to eliminate the toilet or keep it?
-Daniel
PioneerPlumber is offline
Old 11-11-2012, 08:50 AM   #9
seak
If you can tie into the lav drain somehow ( you can use plastic) then you can say **** the vent as long as its 2" pipe your tying in to
seak is offline
Old 11-11-2012, 08:51 AM   #10
seak
but bottom line is you are jackhammering
seak is offline
help with clog between shower drain and toilet. NonChalant Drain and Sewer Cleaning 11 03-14-2012 08:38 PM
Something struck in Toilet drain saivenkat45 Drain and Sewer Cleaning 10 01-02-2012 08:32 PM
Floor drain to shower drain conversion gooch43 General Plumbing Help 1 11-22-2011 12:51 AM
New Toilet makes shower drain gurgle ctchas General Plumbing Help 12 10-29-2011 04:35 PM
Moving toilet drain. jhate83 Toilets and Sinks 5 01-07-2011 03:39 PM
Newest Threads
