Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Toilets and Sinks > Can't remove faucet to replace washer - HELP!
Thread Tools Display Modes
Old 07-01-2012, 05:04 PM   #1
brownknows99
Default Can't remove faucet to replace washer - HELP!
We installed this bathroom faucet a couple years ago and have recently had a slow drip on the cold side. We wanted to remove the faucet handle to replace the washer but cannot get it to come off!
We have removed the set screw (see picture) but the handle won't lift off -- can't figure out what's holding it in place or get to any of the parts. We can't remember the make/model or see any identifying marks or name in order to look up any instructions about it.
Does anyone have suggestions or recognize the model so that we can try to get this fixed? We even had one plumber look at it who couldn't figure out how to remove the handle, either.
Thanks for any help.
brownknows99 is offline
Old 07-01-2012, 11:51 PM   #2
IFIXH20
HERE TO HELP
Liked 236 Times on 187 Posts
Likes Given: 165
First off, retighten the nut under the sink -- If you can't pry that handle off, then the square/bell shape escutecheon under handle should unscrew from the valve body,which should remove the handle assemble.(meaning the square/bell escutecheon and the handle is attach together)
IFIXH20 is offline
Old 07-02-2012, 05:40 PM   #3
Mr_David
Easily Amused
Mr_David's Avatar
Liked 895 Times on 726 Posts
Likes Given: 592
If it has a set screw then it is most likely just bonded to the broach on the end of the stem. Those can be hard to remove sometimes . Can't really spray any type of liquid wrench on it, it may damage the finish and counter top.
disconnect the water supply and finish removing it from the sink. Then try tapping on the bottom of the lever with a block of wood.
a.k.a. Krazedav
Mr_David is offline
Old 07-02-2012, 09:22 PM   #4
IFIXH20
HERE TO HELP
Likes Given: 165
The top portion (handle,escutecheon,and retainer clip or nut) has to be removed to remove stem/valve body, if i am not mistaken.
IFIXH20 is offline
Laundry Tub Faucet Leaks When Washer Is Running?!?! mhoffman54 General Plumbing Help 4 03-03-2012 01:47 PM
How to replace cartridge inside this type of faucet? throne7 General Plumbing Help 17 02-28-2012 02:42 PM
How to remove valve stem in single handle bathtub faucet. wndrwmn67 Plumbing Tools and Equipment 20 03-12-2011 06:51 AM
How do I remove a Bathroom sink faucet that has no screws? Brianm General Plumbing Help 8 12-19-2010 01:55 PM
Replaced fill valve, dripping ceiling and washer faucet Sarby Toilets and Sinks 5 10-25-2010 01:06 AM
Newest Threads
