Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Toilets and Sinks > North - South Equator Flow?
Thread Tools Display Modes
Old 03-02-2010, 12:49 AM   #1
atog254
atog254
Default North - South Equator Flow?
Here is a unique problem!
North of the equator, water flows clockwise down the drain, and counter clockwise south of the equator, RIGHT?
Well I have three toilets in this home in Delaware. Two flow clockwise, and one counter clockwise! The latter one has developed a problem. It will not flush out all paper every other flush. Just seems to slow down once in a while.
I thought the water jets around the rim had gotten clogged over the years and have checked them. (no Problem), I have worked a drain snake through the toilet and pipes (no problem). Still the water flows counter clockwise, and paper will not flush out every flush.
Any ideas? If something were in the drain, why will it flush fine every other flush? Other than this, the toilet runs fine. Have only had to replace the flowmaster..
atog254 is offline
Old 03-02-2010, 10:47 AM   #2
Reedwalker
Expert Turd Herder
Reedwalker's Avatar
Liked 1 Times on 1 Posts
MYTH!
Bowl and plumbing system design are the main factors.
I imagine you either have an issue with your venting, siphon jet pressure is too low, or you're an fart with hard turds. In either case, as long as you're sure there are no obstructions, go get yourself a Toto, American Standard Champion 4, or a Kohler Cimmaron.
Reedwalker is offline
Old 03-03-2010, 09:09 PM   #3
atog254
atog254
Coriolis effect - Water does rotates differently north and south of equator!
atog254 is offline
Old 03-05-2010, 12:39 AM   #4
Reedwalker
Expert Turd Herder
Reedwalker's Avatar
Then how do you explain there being different directions of flow in 1/3 of the toilets in your home?
I searched Coriolis and here's what I came up with.
From wikipedia section 5.3.2
Draining in bathtubs and toilets
Coriolis rotation can conceivably play a role on scales as small as a bathtub. It is a commonly held myth that the every-day rotation of a bathtub or toilet vortex is due to whether one is in the northern or southern hemisphere.
It goes on to say:
In reality, this experiment shows that the Coriolis effect is a few orders of magnitude smaller than various random influences on drain direction, such as the geometry of the container and the direction in which water was initially added to it.
Actually quite interesting. Thanks for giving me a reason to look it up. I really only knew it was a myth from what I was taught in Plumbing School (yes, there is such a thing). I had no idea about Coriolis prior to tonight.
Old 03-05-2010, 07:27 PM   #5
Conway
Conway's Avatar
Damn Reed I have been holding on to that myth for the better part of a decade as truth. Thanks for the correction.
Conway is offline
Old 03-05-2010, 07:39 PM   #6
Austin
Administrator
Austin's Avatar
Liked 91 Times on 85 Posts
Likes Given: 224
I read the Wiki, very interesting.
Austin is offline
Old 04-24-2010, 02:03 PM   #7
PlumbingTheCape
DONT be messing with Reedwalker- he obviously knows his ****- literally hahaha!
There was a think on tv (Brainiac) where they tested this! Pretty interesting stuff but a common myth at that.
Darren Bosman
-Master Plumber-
www.plumbingthecape.co.za
PlumbingTheCape is offline
Old 05-03-2010, 07:00 PM   #8
tbart16
have you removed the toilet from the floor and snaked it backwards? I do maintenance at a school and am often confronted with the every other flush problem usually a cell phone, makeup or some other small flat obect is causing the obstruction. I can usually remove what ever is inside ,but i have smashed a couple toilets to retreive cell phones. good luck
tbart16 is offline
Tags
Equator, North, South, flow, toilet
Low flow in shower twanger1994 Showers and Tubs 4 02-29-2012 04:16 PM
Low flow at tub Charliethyne General Plumbing Help 5 03-27-2011 06:25 PM
South Park Austin General Discussion 10 04-27-2010 01:00 PM
