Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Water Heaters and Softeners > what is a transition fitting?
Thread Tools Display Modes
Old 05-16-2012, 05:56 PM   #1
Another-Plumber
Another-Plumber's Avatar
Liked 6 Times on 5 Posts
Likes Given: 4
Default what is a transition fitting?
gas company came out and tagged a water heater for a customer of mine, the note says needs transition fitting, wtf is that? i called the gas company and they dont know, they will need to send the tech back out in a few days and for me to hang out during the 4 hour window... anyone know what that can be...
Another-Plumber is offline
Old 05-16-2012, 08:08 PM   #2
havasu
havasu's Avatar
Liked 502 Times on 417 Posts
Likes Given: 72
I believe they are referring to a union, which will allow the W/H to be removed and replaced.
havasu is offline
Old 05-16-2012, 09:03 PM   #3
Another-Plumber
Likes Given: 4
cant be, the water heater is in a garage, copper water flexs, gas flex, t&p piped outside, yet, yet they tag it, i have called every plumber i know, googled it, and no one knows shait...
Old 05-16-2012, 09:23 PM   #4
johnjh2o
johnjh2o's Avatar
Liked 399 Times on 319 Posts
Likes Given: 253
Sounds like they may require a dielectric union between the copper and the heater.
John
johnjh2o is offline
Old 05-17-2012, 05:54 AM   #5
IFIXH20
HERE TO HELP
Liked 188 Times on 154 Posts
Likes Given: 136
maybe he/she is talking about a transistion fitting for your gas line, An transition fittings for hard pipe to flex line
IFIXH20 is offline
Old 05-18-2012, 05:48 AM   #6
Another-Plumber
Likes Given: 4
Quote:
John
really the gas company? no... it something stupid, the waterheater to to code,,
Old 05-18-2012, 05:50 AM   #7
Another-Plumber
Likes Given: 4
Quote:
wouldnt it be ok going from black steel pipe to a brass shutoff then flex?
Old 05-18-2012, 12:29 PM   #8
IFIXH20
HERE TO HELP
Likes Given: 136
Quote:
You need a union between the shutoff and the flex (just after the shutoff).If no union , that should be the problem - If you have a union there,codes has changed.
IFIXH20 is offline
Old 05-18-2012, 12:52 PM   #9
johnjh2o
johnjh2o's Avatar
Likes Given: 253
Are you talking about the gas line? If so how would you connect the heater without one?
John
johnjh2o is offline
Old 05-18-2012, 09:53 PM   #10
IFIXH20
HERE TO HELP
Likes Given: 136
John
We are talking about the gas line. How would I connect water heater without one of what ? (Gas line)
IFIXH20 is offline
Florida Condo Water Supply Transition Point: Building to Condo Unit? RD1 Plumbing Building Code 2 06-06-2012 03:42 AM
Y Fitting with Valve? menkes Plumbing Products 4 02-04-2012 03:28 PM
Bathtub and wall transition and waterproofing. DIY345 Showers and Tubs 1 11-07-2011 10:19 PM
Copper/cpvc compression transition pita61 General Plumbing Help 6 10-27-2011 10:57 PM
Swivel fitting joe42 General Plumbing Help 1 10-13-2011 10:36 PM
