Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Plumbing Building Code > Rough in design. Do you approve?
Thread Tools Display Modes
Old 05-15-2012, 03:26 PM   #1
Bogucki
Liked 1 Times on 1 Posts
Likes Given: 4
Default Rough in design. Do you approve?
Tell me what you think. Double vanity being added on this wall. My main concern is the vent pipe distance. It snakes quite a bit.
Bogucki is offline
Old 05-15-2012, 10:54 PM   #2
johnjh2o
johnjh2o's Avatar
Liked 410 Times on 324 Posts
Likes Given: 258
Looks OK to me. What you should do is add a clean out just below or above the DBL fitting. If you try to sanke the line from the sink arms the snake will just run past the DBL fitting with out being able to snake the lower section of the line.
John
johnjh2o is offline
Old 05-16-2012, 02:50 AM   #3
Bogucki
Likes Given: 4
I see. This house is pier and beam so can I add the cleanout under the floor where it slopes toward the main drain? This way I don't have to create an access panel and move the vanity if I need to snake it?? Also, the drain lines from the sink to the double fitting, should they be sloped .25" per foot? I keep seeing examples online and some appear to be level, with no slope. The old drain from the sink that I am tearing out, opposite wall, doesn't have a slope on it. It's flat and tees into the vent pipe that is shared with the toilet. ?? What do you say?
Bogucki is offline
Old 05-16-2012, 03:36 AM   #4
LiQuId
Liked 15 Times on 11 Posts
Likes Given: 20
1/4 " per foot if the pipe is up to 3" 1/8 per foot on 4" minimum grade.
LiQuId is offline
Old 05-16-2012, 02:13 PM   #5
Bogucki
Likes Given: 4
Thanks. 1/4" per foot.
Bogucki is offline
Old 05-16-2012, 02:21 PM   #6
johnjh2o
johnjh2o's Avatar
Likes Given: 258
As far a cover plates for a clean out these work very well for very little cost. You can have the clean out inside the wall with this plate over it.
http://www.oatey.com/Channel/Shared/ProductGroupDetail/370/Stainless+Steel+Cover+Plates.html
John
johnjh2o is offline
Old 05-16-2012, 04:30 PM   #7
Bogucki
Likes Given: 4
Thanks. One last question. Would you use copper or PEX for the supply lines? I've read alot about the two but everything seems to be based on personal opinion. I've never sweated pipes before but I'm confident I can become proficient with some scrap pieces and a little practice. Is it worth the time and money to put in copper?
Bogucki is offline
Old 05-18-2012, 03:10 AM   #8
LiQuId
Likes Given: 20
nope, copper is nice for mechanical rooms and areas that may be seen, but for most domestic perposes sees little benafit Imo.
LiQuId is offline
Old 05-19-2012, 01:01 AM   #9
bnut1973
Hi I'm Brian. Everything looks ok to me. I would do it different though. The one thing that I don't think u need is a clean out. If u have your double Ty going the right direction u won't have a .problem snaking it ever. You can also go as minimal as 1/16 of an inch on your pitch for vent if needed. It's a vent not a drain. I would use pex if your not so sure on the sodering. Another thing is reduce to 1 1/2 for the drain and venting. 2 inch is not needed, easier to work with. Good luck! Any questions ask.
bnut1973 is offline
Old 05-19-2012, 01:05 AM   #10
johnjh2o
johnjh2o's Avatar
Likes Given: 258
Quote:
If you have a stoppage below the DBL TY there is no way to get the snake to go down the line. When running the snake through one waste arm it will go past the drop and into the other waste arm.
John
johnjh2o is offline
System Design TheNapster87 Plumbing Building Code 7 12-20-2012 09:46 PM
design help Greg General Plumbing Help 2 07-02-2012 05:18 PM
Custom Shower Design? Bogucki Plumbing Building Code 5 05-23-2012 08:19 PM
