can you believe this.
Where do I find the chemical formula for wood? WO2Dy. (Tungsten, oxygen and dysprosium...WOODy,:eek:)
Poor little wood peckers in CA must be kickin'...or pecking...down the doors for radiation treatment.
Curious, though...why doesn't the wood in other parts of the country cause cancer? Those giant Sequoias should all be chopped down, bein' all riddled with carcinogens and all.
And those are the normal ones. You should see the people you don't know.
Tomorrow they will have warnings floating in the air about it causing cancer.
...sometime after they figure out how to sell portions of atmosphere for projection advertizing...
Id like to see plywood generate wood dust.
I've seen saws generate dust, but not the plywood.... :D
Look at you getting all technical.
Contact the state of California. They may not know that.
Didn't your Daddy ever have "The Talk" with you?
Obviously you have never seen two sheets of plywood going at it. A dust storm that would make an Iraqi scared, and at the end of it, a napkin sized piece of plywood is born.
