Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Showers and Tubs > Silicone caulk around base of shower door track
Thread Tools Display Modes
Old 04-22-2012, 07:54 PM   #1
Dawgintupelo
Default Silicone caulk around base of shower door track
When we bought this house about 17 years ago, there were clear silicone beads of caulk on each side of the track base and we had a new shower door (with new track) who also put down a nice bead of silicone on each side. Now, after years of use, the caulk on the bathtub side of the track base has a lot of mildew in it. How do I cut away the old silicone without cutting the fiberglass tub portion under the silicon? Is there a special tool for this?
Thanks in advance,
Rod
Dawgintupelo is offline
Old 04-23-2012, 01:02 AM   #2
havasu
Administrator
havasu's Avatar
Liked 1057 Times on 853 Posts
Likes Given: 290
I have yet to find a simple way to remove silicone except for a sharp razor blade, careful hands, and as flat as possible on the fiberglass so as to not scratch it. You may find a chemical such as "Goo Be Gone" or similar, but do a test on the fiberglass to ensure it will not damage the surface.
havasu is offline
Old 04-25-2012, 01:36 AM   #3
Mr_David
Easily Amused
Mr_David's Avatar
Liked 756 Times on 609 Posts
Likes Given: 531
Only the outside should be caulked.
This allows moisture to drain out from under the bottom rail.
Most installation directions that I have read regarding tub / shower doors have stated not to caulk the inside. You would be suprised as to how many installers actually take the time to read them.
I hate silicone hery hard to clean off if it made a good bond to surface.
if the surface was not clean it may just peel off
a.k.a. Krazedav
Mr_David is offline
Old 04-25-2012, 04:29 AM   #4
digitalplumber
Quote:
Thanks in advance,
Rod
We bought some caulk remover in a squeeze pump spray bottle from Lowes, worked great.
digitalplumber is offline
Shower Base flush to wall? Bogucki Showers and Tubs 16 11-20-2013 03:20 PM
tile ready shower base reviews davschmidt Showers and Tubs 1 12-09-2011 04:07 PM
shower base mijoda52 Showers and Tubs 2 10-14-2011 01:02 PM
Tiled shower caulk question digitalplumber Showers and Tubs 5 03-06-2011 12:57 AM
no caulk shower drain holecz General Plumbing Help 1 12-30-2010 10:18 PM
Newest Threads
