Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Pumps and Wells > My Jet pump turns on with no water usage.
Thread Tools Display Modes
Old 03-31-2012, 02:11 PM   #1
Jaytills
Default My Jet pump turns on with no water usage.
Hello, I have a deep well jet pump that keeps turning on every 30 minutes even when not using water. The jet body was replaced a year ago and everything was ok until about 2 weeks ago. I've had a plumber here twice already. They replaced my pressure seating foot valve with a spring loaded one. then had to replace that one because it was damaged. The strainer was bent. Each time the system seems fine when they leave. I run water from the bottom of the tank for a few hours to get rid of sediment but then after that the pump goes back to turning on every 30 minutes. The tank was tested and is ok. I've isolated the house by closing the ball valve between the tank and house and still loose pressure. The lines going from the house and into the well were pressure checked by the plumber by removing the exsisting pressure gauge on the pump with one with a shrader valve. The ball valve between the pump and tank was closed and then a compressor was hooked up and the lines and pump were pressurized to 90 psi. There wasn't a noticeable pressure drop. Im really not sure where to go from here. Do I have them issolate each line and pressure check them separately? Any help would be appreciated.
Jaytills is offline
Old 03-31-2012, 02:29 PM   #2
johnjh2o
johnjh2o's Avatar
Liked 717 Times on 544 Posts
Likes Given: 610
When you say he replaced the check valve where was it located? There should be a foot valve a the end of the line in the well. It sounds like the foot valve is leaking or you have a leak between the pump and the well.
john
johnjh2o is offline
Old 03-31-2012, 03:34 PM   #3
Jaytills
John, the foot valve was replaced. It's at bottom of of jet body in the well. I'm thinking I have a leak in the piping from the well to house but they said they checked it already by the method I mentioned above. I'm leaning towards pulling the line apart and testing each line separately before I start digging. Just wondering if there is a better way.
Jaytills is offline
Old 03-31-2012, 03:41 PM   #4
Jaytills
I guess another question would be if the lines are ok and I still have a problem. Is there a different kind of foot valve I can use? The original one was plastic and was seated by the system pressure which was fine for almost a year. The new one is brass and seats with the aid of a spring. The foot valve is 1-1/4".
Jaytills is offline
Old 03-31-2012, 03:45 PM   #5
johnjh2o
johnjh2o's Avatar
Likes Given: 610
Are you planing on pulling them apart at the well head? Instead of testing them separately twin them together at the well head a test them both at the same time. It could still be the foot valve. Because when the lines were pulled to replace the first foot valve debris in the lines could have dropped into the new foot valve causing it not to seal. The only sure way to prevent this is to replace the lines.
John
johnjh2o is offline
Old 03-31-2012, 05:37 PM   #6
Jaytills
John, thanks so much for the replies I was going to separate the lines at the well head and test the two lines going from well to house separately. Then I was thinking i could put a plug on the end of one line going into well (probably the discharge side) and then putting a fitting with the same kind of gauge the plumber used in the end of the side that sends water to the jet assembly so I can pressurize both lines and the jet assembly at same time. Will this work? If the foot valve is still leaking you would suggest replacing the lines going into well?
Jaytills is offline
Old 03-31-2012, 06:27 PM   #7
johnjh2o
johnjh2o's Avatar
Likes Given: 610
If you test both lines from the house to the well and there OK then you know you have a bad foot valve or a bad line in the well. At that point you have to pull the lines from the well to make your repair. If you have to go that far I would suggest you replace the lines and the foot valve with new. There not that expensive. Unless you like doing things twice.
John
johnjh2o is offline
Old 04-01-2012, 01:15 PM   #8
Driller1
Driller1's Avatar
Liked 1 Times on 1 Posts
Quote:
Why a plumber???
Call a well driller.
Also, check to see if it is wet around the wellhead.
Is your water cloudy or dirty???
Driller1 is offline
Old 04-01-2012, 03:45 PM   #9
Jaytills
The plumber I use has a separate crew that do only wells and the previous owner had them install the pump and pressure tank in 2006 so that's why I called them. Once the initial sediment that was stirred up by removing the jet body assembly was flushed out the water is very clear. Looks like a good quality city water supply. I have not noticed any wet areas around the well or anywhere between well head and house. The well head is in a concrete box and about 3' below grade.
Jaytills is offline
Old 04-02-2012, 02:15 PM   #10
speedbump
Wells & pumps; not a...
speedbump's Avatar
Liked 211 Times on 192 Posts
Likes Given: 46
If these guys were knowledgeable about wells/pumps etc. They wouldn't have tested the pipes with air. Air compresses, so it would take quite a while to notice a drop in pressure. Water on the other hand does not compress, so a drop of water can reduce the pressure from 50 to zero with a totally waterlogged tank.
I doubt that your footvalve being brass is the problem if its fairly new. What kind of jet do you have? A single pipe or a two pipe? If a single pipe, did they change the leathers?
speedbump is offline
Toilet refils ONLY when sink turns on kimbo Toilets and Sinks 5 11-05-2011 08:03 PM
Hot Water Heat and Pump andy867 Water Heaters and Softeners 4 05-11-2011 02:03 PM
Hot water recirc pump installed, now hot water in cold lines? hevykevy420 General Plumbing Help 0 09-09-2010 03:35 PM
Water usage DMC General Plumbing Help 7 07-16-2010 05:07 PM
Water pump in my RV Chris General Plumbing Help 2 02-12-2010 03:18 PM
Newest Threads
