Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Toilets and Sinks > Kitchen sink sprayer leaks (or: what is this part?)
Thread Tools Display Modes
Old 03-26-2012, 10:57 PM   #1
matbluvenger
Default Kitchen sink sprayer leaks (or: what is this part?)
Hey all! First post here, have a problem.
Last night all of a sudden the hose leading to the sprayer would shoot water all over the place under the sink when it turned the faucet on.
I'm not even sure what this piece is called.... but the leak is coming from where the black hose on the left connects to the plastic manifold, almost as though the hose just separated from it.
I'd just like to know what the plastic piece is called and if fixing that hose is as simple as just reconnecting it.
Thank you very much in advance!
matbluvenger is offline
Old 03-26-2012, 11:00 PM   #2
havasu
Administrator
havasu's Avatar
Liked 1130 Times on 922 Posts
Likes Given: 350
Those connections are usually made at the factory and I don't know if it is serviceable.
havasu is offline
Old 03-27-2012, 03:15 AM   #3
jmulla
jmulla's Avatar
Liked 1 Times on 1 Posts
Likes Given: 9
Some of those connectors are simply push fit. See if there is a collar that you can push down and then pull on the pipes. Then you can cut off the end of the leaking pipe and re-push it into the connector.
jmulla is offline
Old 03-28-2012, 12:33 AM   #4
LiQuId
Liked 15 Times on 11 Posts
Likes Given: 20
a picture of the faucet would help TONS!!!
likely this in not a serviceablle part, but it could be.. without knowing the make it is impossiblle to properly determine.
LiQuId is offline
Old 03-31-2012, 02:24 PM   #5
SlowDrip
Plumbing Sales
SlowDrip's Avatar
Gonna back up what others have said here. In 95% of cases that part is non serviceable, it uses a special factory-installed fitting that locks into the push fitting (I am assuming that is a white push fitting with a blue plastic "clamp" that locks over the end of the hose.)
If it is a good faucet manufacturer they will be able to get you a replacement part. If it is a cheapy....toss and replace.
SlowDrip is offline
Bathroom Sink Base Constantly Leaks mrcannon Toilets and Sinks 9 08-19-2012 02:02 AM
Low water pressure from kitchen faucet until i turn on hose sprayer flygirl Toilets and Sinks 3 02-10-2012 12:51 PM
Kitchen faucet leaks dipam General Plumbing Help 6 08-11-2011 12:08 PM
Pulsating or jumping kitchen sprayer advizo Toilets and Sinks 1 07-14-2011 12:29 AM
Sink sprayer has a very weak stream bgrubba Toilets and Sinks 3 01-15-2011 02:37 PM
Newest Threads
