Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Toilets and Sinks > Washing machine backing up thru toilet
Thread Tools Display Modes
Old 02-08-2010, 08:47 PM   #1
rapidtexter
Default Washing machine backing up thru toilet
my washing machine is in garage..front toilet and shower on same wall...water from last wash load backed up and flooded thru toilet and shower drain...how bad and expensive of a problem is this??
rapidtexter is offline
Old 02-08-2010, 09:54 PM   #2
Chris
Administrator
Chris's Avatar
Liked 931 Times on 786 Posts
Likes Given: 67
Quote:
You probably just plugged up a pipe in that wall that will need to be snaked.
Chris is offline
Old 02-08-2010, 10:14 PM   #3
rapidtexter
Quote:
Thank you Chris...how hard is it to do that myself? Could I rent the snake and do or am I best to get a professional??
Old 02-08-2010, 10:21 PM   #4
Chris
Administrator
Chris's Avatar
Likes Given: 67
I have a small hand held snake that I use on clogs as long as they are within 20 feet. It is definitly something you can do and you can always rent a snake if you don't want to store one.
Chris is offline
Old 02-09-2010, 02:09 AM   #5
SilverBack4Jack
Always Learning.....
SilverBack4Jack's Avatar
Does your toilet still flush? Did it back up into the shower and overflow onto the floor or did you actually see it backing up out of the toilet? If it came out of the toilet it is more than likely not just in the wall.
Well you see what had happened was....
SilverBack4Jack is offline
Old 02-09-2010, 02:57 PM   #6
majakdragon
If the toilet is backing up, this tells me you have a main drain clog. Toilets are on a 3 or 4" drain line. They are also, normally, connected to the house main drain line.
If you have never made a mistake, you probably haven't done much.
majakdragon is offline
Old 04-24-2010, 01:59 PM   #7
PlumbingTheCape
Quote:
Agreed, the problem is further that the toilet. And not the washing machine line as it obviously pumped the water out the toilet!!!!
Darren Bosman
-Master Plumber-
www.plumbingthecape.co.za
PlumbingTheCape is offline
Tags
washing machine, clog, backing up, toilet
Washing machine hookup alisa211 General Plumbing Help 7 07-14-2014 06:51 AM
Washing Machine Drain monday8908 General Plumbing Help 1 06-13-2012 12:19 PM
Washing machine plumbing nickb7 General Plumbing Help 10 07-28-2010 05:01 PM
Any of you guys take apart a washing machine? Chris General Plumbing Help 7 02-26-2010 07:26 PM
Loud Washing Machine? Conway General Plumbing Help 3 01-14-2010 07:47 PM
Newest Threads
