Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Adding a sink
Thread Tools Display Modes
Old 02-08-2010, 08:23 PM   #1
artaman
Default Adding a sink
I am buying a newly built home with a long counter in one of the bathrooms. I asked the builder if he could add another sink and tie into the existing service and drain lines under the existing sink. He said it would be very expensive and he would have to install additional drain and service lines. Since one sink is already there (with exposed plumbing under this sink) how difficult would it be to just tie into the existing plumbing? What is a ball park estimated cost to do this? Would the builder have to pull a permit (home is in Texas)?
THANKS
artaman is offline
Old 02-09-2010, 12:57 AM   #2
phishfood
Administrator
Liked 964 Times on 775 Posts
Likes Given: 1739
Since the builder is going to do things to code, and probably pull a permit, and call his plumber back, and his cabinet guy, and maybe drywall repair, to protect himself, it probably would be quite expensive. I don't deal with the pricing and cost side of the business, so I can't really help with that.
phishfood is offline
Old 02-09-2010, 01:24 AM   #3
Reedwalker
Expert Turd Herder
Reedwalker's Avatar
Liked 1 Times on 1 Posts
Yeah what Phish said.
Except he forgot paint
Plumber for rough in, inspection, finish, and inspection = $400 - $700
Cabinet removal and re-install = $200 - $400
Countertop = Too many variables
Paint = $150 - $250
Plus permits and inspection fees. Likely a 5 - 8 day process.
Reedwalker is offline
Old 02-10-2010, 01:15 AM   #4
phishfood
Administrator
Likes Given: 1739
Darn paint gets me every time!
Old 02-21-2010, 08:34 AM   #5
Plumbermurrieta
Banned
Adding a bathroom sink to your existing vanity area can be costly and time consuming if you pay a contractor or plumber to do it. You can do this job with a few simple considerations. If you are adding the second sink on the same wall, the basins should be no more than 30 inches apart due to drainage issues and pipes.
Plumbermurrieta is offline
Old 03-02-2010, 03:32 PM   #6
PipePig101
PipePig101's Avatar
I am just finishing up the same thing and posted a couple of questions on another thread here. But I will tell you it is alot of WORK! Don't let the wife talk you into installing a recessed mirror.
So far, DYI it has cost me about $3K for the parts (new vanity granite/double sink and faucets, mirror box) and I found that the guy before me installed the tile floor AROUND the old vanity. Now I have to re-tile the floor too.
PipePig101 is offline
Tags
add a sink, sink, sink plumbing
Adding three sink to washer drain vaportx Plumbing Building Code 13 01-19-2013 01:00 AM
stak config. adding laundry sink Tom General Plumbing Help 0 10-25-2011 08:28 PM
Adding a bar sink to a basement lav rough-in andrejk General Plumbing Help 2 08-25-2011 01:47 PM
adding basement sink near the dwv stack ew1439 General Plumbing Help 6 11-19-2010 12:52 AM
Adding a dual sink havasu Toilets and Sinks 13 02-05-2010 09:37 PM
Newest Threads
