Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Custom shower - water lines after valve
Thread Tools Display Modes
Old 02-23-2012, 05:42 PM   #1
jusluv2ski
Default Custom shower - water lines after valve
I have a 3/4" thermostatic valve to a 3/4" inlet of the diverter valve. the diverter has 3 - 1/2" outputs. Fixtures(3 body sprayers, handheld and head) are 1/2". I am on a well. Does it help my water pressure and/or volume to convert the 1/2" outputs to 3/4" then back down to 1/2" at the fixtures? i thought someone told me this but i can't remember why. or am i ok with 1/2" straight to the fixtures? the diverter valve is capable of running 2 of the 3 fixtures at a time.
thanks
jusluv2ski is offline
Old 02-25-2012, 11:25 AM   #2
phishfood
Liked 481 Times on 392 Posts
Likes Given: 643
1/2" to the separate heads will be fine. The restriction provided by the heads will not allow even as much flow as the 1/2" will provide.
Lake County, Florida plumber
Springtime Plumbing Services, LLC
License #11067533
352-630-5673
phishfood is offline
Old 02-25-2012, 05:41 PM   #3
Plumbero007
Plumbero007's Avatar
what is your pump well pressure, at start of cycle and end of pumping cycle?. to run 3 heads you will need at list 55 psi
Stan
remodel-my-bath.com
Serving ATLANTA and North West GA since 1992
http://remodel-my-bath.com
Plumbero007 is offline
Custom Shower Design? Bogucki Plumbing Building Code 5 05-23-2012 08:19 PM
Connecting shower faucet to supply lines bwspot Showers and Tubs 7 05-02-2012 04:19 AM
Old Custom Shower pan retaining water standupguy Showers and Tubs 3 02-21-2012 11:18 AM
New shower valve, no hot water? Chris112 General Plumbing Help 3 03-24-2011 04:21 PM
Question: custom shower pan (problems) nuklep General Plumbing Help 10 03-22-2010 07:08 AM
