Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Water Heaters and Softeners > Pilot light will not stay lit.
Thread Tools Display Modes
Old 02-19-2012, 08:25 PM   #1
jeff
Default Pilot light will not stay lit.
Hello All, I've been troubleshooting this for the past three weeks. apollo water heater approx three years old. pilot light seems to go out whenever the main burner shuts off. First fix attempt, I removed the burner and pilot assy, cleaned, and blew out lines, put back on and worked great for about two days. Second attempt, replaced pilot light assy, once again, worked for about two days. pilot light lights up fine, and if I leave it at a low temp, without the main burner coming on, the pilot light stays lit indefinitely. When I manually turn the temp up, causing the main burner to come on and than turn the temp back down so the burner goes out, the pilot light will stay lit. It seems to only go out when the burner shuts off automatically after water reaches correct temperature. Checked air vents on bottom of tank and they are clean. If anyone has a suggestion on what the problem might be, please let me know, Thank You.
jeff is offline
Old 02-19-2012, 11:19 PM   #2
havasu
Administrator
havasu's Avatar
Liked 1130 Times on 922 Posts
Likes Given: 351
You need to replace your thermocouple.
http://www.americanwaterheater.com/s...t_tc_instr.pdf
havasu is offline
Old 02-20-2012, 03:16 AM   #3
Another-Plumber
Another-Plumber's Avatar
Liked 6 Times on 5 Posts
Likes Given: 4
post a pic of the base of the heater if you can, ill solve it for you
Another-Plumber is offline
Old 02-20-2012, 06:18 AM   #4
LiQuId
Liked 15 Times on 11 Posts
Likes Given: 20
thermocouple for sure..
LiQuId is offline
Old 02-20-2012, 10:37 AM   #5
jeff
Replaced the thermocouple with the pilot assy.
jeff is offline
Old 02-20-2012, 12:48 PM   #6
johnjh2o
johnjh2o's Avatar
Liked 726 Times on 550 Posts
Likes Given: 620
There was a problem with some of the newer gas heaters. They get there combustion air from under the heater through a filter. These filters after time, depending on the location of the heater would become plugged. They have a brush that is used to clean these filters.
http://www.statewaterheaters.com/cust/FVIRCleaning.pdf
John
johnjh2o is offline
Old 02-20-2012, 05:40 PM   #7
jeff
Checked filters at bottom of tank and they are clear
jeff is offline
Old 02-21-2012, 06:59 AM   #8
LiQuId
Likes Given: 20
so, is it working ?? or is the problem persisting ?? we're kinda in the dark .
LiQuId is offline
Old 02-21-2012, 10:35 AM   #9
jeff
still not working, the only time it works for longer than a day is when I remove the pilot, burner and thermocouple from the valve and put them back on, then it works for a day or two and than the problem starts reoccuring.
jeff is offline
Old 02-21-2012, 01:18 PM   #10
Another-Plumber
Likes Given: 4
post a picture of the base, with the front sheild cover off
Faucet won't stay on (video) xfactor General Plumbing Help 7 02-23-2014 07:47 PM
FVIR Water Heater Pilot wont stay lit after cleaning filter arcsum68 Water Heaters and Softeners 33 11-29-2013 03:35 PM
Italian water heater not working - pilot won't stay lit bushmlev Water Heaters and Softeners 3 06-01-2011 03:59 PM
Pilot light outage PJC Water Heaters and Softeners 1 02-25-2011 05:46 PM
New Gas Water Heater Won't Light Leaksealer General Plumbing Help 4 07-19-2010 03:37 PM
Newest Threads
