Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Is this for the city or us?
Thread Tools Display Modes
Old 02-12-2012, 10:15 PM   #1
menudoboy
Default Is this for the city or us?
I noticed the dial on the water meter was barely turning when the valve was completely shut off. I didn't think that much of it but the next day when I read the meter it had increased one whole number in 24 hours with it having been completely off. Not sure if that is 10 gallons per digit or 100 gallons. Either way that can add up in 1 month. Tomorrow (Monday) I plan to call the city. The valve handle is completely rusted off just about to where it's only a nub. My hand is moist when turning the valve so I imagine all the corrosion made the valve leak.
However, from my understanding, any leak that causes the dial to turn, I understand it to be the customer's responsibility since anything after it is considered on our side of the meter.
Does anyone know for sure if a valve leak on the city meter is the city's responsibility or the customers?
Thanks
menudoboy is offline
Old 02-12-2012, 10:51 PM   #2
Another-Plumber
Another-Plumber's Avatar
Liked 6 Times on 5 Posts
Likes Given: 4
customers responsibility if the little dial turns, yes that means you have a leak some where down line, (underground or inside the home)
Another-Plumber is offline
Old 02-12-2012, 11:07 PM   #3
menudoboy
We already know we had a leak. That was the reason we shut the water off to begin with. But no this particular leak referred to here is leaking at the city's overly corroded shut off valve.
Once you shut the water off, it's not suppose to leak and the dial is not suppose to turn.
Old 02-12-2012, 11:32 PM   #4
Another-Plumber
Likes Given: 4
they are only responsible for the meter and meter only, you might get lucky and they will fix it
Old 02-13-2012, 12:57 AM   #5
Mr_David
Easily Amused
Mr_David's Avatar
Liked 837 Times on 678 Posts
Likes Given: 554
here The city does not want you turning off their valve before the meter.
If it needs to be turned off Call them. If their valve does not hold 100% then it is their responsibility to be able to stop the water going to the meter. Oncer they turn their side off, that will enable you to install a working valve after the meter.
a.k.a. Krazedav
Mr_David is offline
Old 02-13-2012, 01:14 AM   #6
Plumbero007
Plumbero007's Avatar
Water meter valve on street side with padlock holes belongs to the city and should be the City's responsibility. As mr_Dave above responded if that valve is not working City should fix it.
After that you be able to turn working valve off and see if meter is moving. If so, hunt for leaks on your side of the water meter.
Stan
Stan
remodel-my-bath.com
Serving ATLANTA and North West GA since 1992
http://remodel-my-bath.com
Plumbero007 is offline
Old 02-13-2012, 08:06 AM   #7
LiQuId
Liked 15 Times on 11 Posts
Likes Given: 20
I just wanted to clarify for the Op that the meter would not be spinning if the leak was before the meter, the meter registers water passing through it, so therefore the leak would be downstream of the meter. check your toilets, a worn out flapper can cause minute leaking that is sometimes not realized.
LiQuId is offline
Old 02-14-2012, 12:08 AM   #8
Caduceus
Caduceus's Avatar
Liked 348 Times on 254 Posts
Likes Given: 230
Different areas have different rules for ownership. Best to call the city and find out. BTW, my Neptune ECoder R900i water meter will also spin if the leak is before the meter. I am told that it is designed to register water use before the meter to prevent theft of water and to charge for service line leaks that the owner is responsible for.
Caduceus is offline
Old 02-14-2012, 12:21 AM   #9
LiQuId
Likes Given: 20
I suppose that is true they are now making meters that will register reverse flows, but assuming it is a traditional meter, and If they have the neptune ecoder they would just look at the display to see the reverse arrow and the - flashing indicating reverse flow occuring ( leak before the meter. )
so I suppose the question would be, what type of meter is installed?
LiQuId is offline
Old 02-14-2012, 08:49 AM   #10
Another-Plumber
Likes Given: 4
very hard to belive, the leak sensor will rotate with movement before the meter?... no matter what i wont belive this unless you post a link with some sort of proof, beside if someone is clever to tap into a live line, awe what am i sayin, just show me the link to that kind of meter..
Discuss. Well or City water? Chris Pumps and Wells 23 04-20-2016 02:16 PM
Pressure Tank for City Water TxBuilder Pumps and Wells 1 07-17-2012 10:05 PM
