Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Toilets and Sinks > Toilet doesn't refill after flushing?
Thread Tools Display Modes
Old 01-17-2012, 04:55 PM   #1
tflo77
Default Toilet doesn't refill after flushing?
I recently replaced refill valve, since then the toilet doesn't refill after flushing.
What could I have done wrong in the process? I currently would have to go in and manually push down on the lever to the refill valve to get the toilet to refill.
tflo77 is offline
Old 01-17-2012, 05:21 PM   #2
havasu
Administrator
havasu's Avatar
Liked 1114 Times on 906 Posts
Likes Given: 336
Sounds to me like your float valve is binding. Check for this, and if it is not the case, it may be possible you have a defective valve.
havasu is offline
Old 01-17-2012, 06:09 PM   #3
tflo77
Simply check and see if there's a jam with the float valve?
tflo77 is offline
Old 01-17-2012, 07:40 PM   #4
havasu
Administrator
havasu's Avatar
Likes Given: 336
Exactly. Can you post a picture of what you have done? Did you replace the flapper? Is the chain adjusted correctly? Did you install what is pictured below?
havasu is offline
Old 06-08-2012, 02:51 AM   #5
dpotesta
I have a problem with my tank not refilling either. The parts seem okay, the flow into the tank is minimal. If I reach under and cut off the main water valve then crank it back open the tank immediately fills. Flush again and the water trickles in. Close and open the valve and it again fills immediately.
dpotesta is offline
Old 06-08-2012, 05:56 AM   #6
havasu
Administrator
havasu's Avatar
Likes Given: 336
Sounds like a blocked/broken valve to me. Remove the supply line to the toilet (after draining the tank) and place it in a bucket and open and close the valve several times to see it you get sediment. If so, the top of the float is probably clogged with sediment as well.
havasu is offline
Old 06-13-2012, 02:25 PM   #7
havasu
Administrator
havasu's Avatar
Likes Given: 336
I'm at my vacation house right now and am having the same problem with the bowl receiving less water than normal. Upon looking closer, I saw the small plastic tubing was pinched, choking off the water in the bowl.
havasu is offline
Old 06-16-2012, 11:25 PM   #8
desertwater
desertwater's Avatar
Quote:
Sounds like you have a flood safe supply line! They shutoff the water flow if a certain amount of water passes through them.
desertwater is offline
Old 06-17-2012, 01:23 AM   #9
johnjh2o
johnjh2o's Avatar
Liked 722 Times on 546 Posts
Likes Given: 615
Quote:
Let me add if you have a flood safe supply line take it out. There have been many failures with them.
John
johnjh2o is offline
Old 06-17-2012, 02:43 AM   #10
desertwater
Quote:
John
Exactly, I should of been more clear.
Toilet Flushing Issue mdalasta Toilets and Sinks 1 12-05-2011 12:17 AM
Toilet Flushing psk09 General Plumbing Help 1 10-12-2011 09:18 PM
Toilet won't refill without help mg21dg Toilets and Sinks 3 04-04-2011 04:07 PM
Slow Flushing Toilet? Kawiski Toilets and Sinks 3 07-08-2010 03:26 PM
Toilet cistern slow to refill + loft water tank making noises / empty? tomcorrigan Toilets and Sinks 2 06-07-2010 12:34 AM
Newest Threads
