Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Crust on water heater pipes?
Thread Tools Display Modes
Old 01-05-2010, 11:06 PM   #1
Louie4
Injanir
Louie4's Avatar
Default Crust on water heater pipes?
My parents have a dual (gas) water heater system and there is some kind of build up on the inlet and outlet pipe on one of them (main one used I guess). The build up is around the spot where the pipes go into the water heater and I'm wondering what it is and why is it on the outside of the water heater? I know mineral deposits build up on the inside but not sure why its on the outside. Just to mention my folks are on a well so I'm sure the water is mineral rich.
I'll try to get pics after this weekend.
Louie4 is offline
Old 01-05-2010, 11:20 PM   #2
Local16 Omaha
Your #2 is my #1
The connections are probobly leaking. Slow enough you dont notice it.
Local16 Omaha is offline
Old 01-05-2010, 11:22 PM   #3
'Cause
My drains are stopped up
'Cause's Avatar
Liked 1 Times on 1 Posts
Most likely caused by diss-similar metals, IE. copper to galvanized piping. You may want to look into installing dielectric fittings to separate. If what you see is a white powdery substance, that is what it most likely is.
'Cause is offline
Old 01-05-2010, 11:25 PM   #4
Local16 Omaha
Your #2 is my #1
Yep forgot about that. Good call 'Cause
Old 01-05-2010, 11:51 PM   #5
Louie4
Injanir
Louie4's Avatar
Thanks guys. I'm guessing its the connections. I'll check the connection on the water heater. The build-up is a white/yellowish powder.
I'm wondering why its not happening on the other water heater right next to it? Maybe because its the secondary one.
Louie4 is offline
Old 01-06-2010, 05:45 PM   #6
hcj
Default build up
No, it is because that is the only one with leaking pipes.
hcj is offline
Tags
water heater, pipes, build up, dielectric, leak
4 pipes coming from water heater? emo7874 Water Heaters and Softeners 3 01-28-2012 05:13 PM
Sand coming into tub from pipes after replacing old pipes Dearly Showers and Tubs 4 01-15-2012 04:15 PM
buzzing water pipes raypunzel General Plumbing Help 3 09-22-2011 12:54 AM
Running water in Pipes tkutch General Plumbing Help 7 11-04-2010 06:25 PM
water pipes banging stanny General Plumbing Help 1 05-01-2010 04:26 AM
