Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Plumbing Building Code > Elbow Placement
Thread Tools Display Modes
Old 01-16-2012, 07:17 PM   #1
thriftyhiker
Default Elbow Placement
I'm installing a new water softener. I have a very small area to tie in to the water line between the pressure regulator and the T that goes to the water heater. The pipes are in the wall and I need to run them out of the wall. This will require a lot of elbows. There is one area I'm going to have to use 3 elbows in about 10 in of line or less. I'm using 3/4 in PVC. Is there a code, regulation, or rule of thumb about how many elbows you can use in a certain amount of space?
thriftyhiker is offline
Old 01-16-2012, 08:05 PM   #2
LiQuId
Liked 15 Times on 11 Posts
Likes Given: 20
No, excessive elbows will cause turbulant flow and age the pipe faster also risking the pipes being loud when in use but there are no code limitations, use 45's where you can to reduce flow restriction.
LiQuId is offline
Old 01-16-2012, 08:22 PM   #3
thriftyhiker
Thanks. Here's what I'm working with. The water supply comes up from the bottom right (behind drywall), comes out of the wall, goes through a shut off valve and the pressure regulator (just below were picture cuts off), reenters the wall, turns left through a 2X4 and Ts. The up T is to the water heater, the down is the main cold water supply. Any advice on how to route the pipes for the softener?
Old 01-16-2012, 09:00 PM   #4
johnjh2o
johnjh2o's Avatar
Liked 726 Times on 550 Posts
Likes Given: 620
PVC is not allowed inside a building. But it looks like you have CPVC you may have thought it was PVC.
John
johnjh2o is offline
Old 01-16-2012, 09:07 PM   #5
thriftyhiker
Right, same questions though.
Old 01-17-2012, 01:28 AM   #6
johnjh2o
johnjh2o's Avatar
Likes Given: 620
If your water pressure is good I don't think I would be to concerned.
John
johnjh2o is offline
Old 01-20-2012, 04:25 PM   #7
KULTULZ
Jack of All Trades ~ Master of None
KULTULZ's Avatar
Liked 316 Times on 277 Posts
Likes Given: 172
Not polite to break in, but...
Quote:
Thanks for that tip!
Quote:
John
R U saying PVC SCH 80 is not allowed to be used in indoor (pressure tank to filter system - no hot water introduced - CPCV from after filters) plumbing?
- PLUMBER'S GUIDE TO SUCCESS -
1) Hot On Left - Cold On Right
2) Shiat Flows Downhill
3) Lefty Loosey - Righty Tighty
4) Do Not Bite Nails
5) Plunge With Mouth Closed
6) Leave No DNA On Job Site
7) Just Say No To Plumber's Crack
8) Boss is PIA - His Wife Is Looker
9) Payday On FRI
10) There Is NO LH Monkey Wrench
KULTULZ is offline
Old 01-20-2012, 04:43 PM   #8
johnjh2o
johnjh2o's Avatar
Likes Given: 620
Where did he mention SCH 80 PVC.
John
johnjh2o is offline
Old 01-20-2012, 07:55 PM   #9
KULTULZ
KULTULZ's Avatar
Likes Given: 172
John
I a$$-u-med that when he compared CPVC usage also.
PVC is allowed within a filtering system, correct? CPVC afterwards?
9) Payday On FRI
KULTULZ is offline
Old 01-20-2012, 09:29 PM   #10
johnjh2o
johnjh2o's Avatar
Likes Given: 620
In my area PVC is not allowed inside the home. If the filter system is out side it is allowed.
John
johnjh2o is offline
P-trap placement Rohey General Plumbing Help 15 12-31-2011 04:30 PM
Pinhole leak at elbow joint. Possible fix? jaws General Plumbing Help 2 09-21-2011 12:05 PM
2" long radius galvanized elbow Studhauler General Plumbing Help 6 07-24-2011 09:16 PM
PEX elbow ASTM F845 replacement?? mrsray Plumbing Products 0 03-24-2011 12:57 PM
Newest Threads
