Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Concern/Risk using CPVC at Shower
Thread Tools Display Modes
Old 09-28-2011, 03:01 PM   #1
burchis
Default Concern/Risk using CPVC at Shower
I am roughing-in an extra bathroom and plan on using CPVC for service. I have read that there is a lot of expansion and compression with this material.
My concern is with the supply line from the bathtub faucet up to the shower head, which is about 48".
Since both ends will be securely fastened what problems could I expect? What options do I have?
Thanks for your replies.
burchis is offline
Old 09-28-2011, 04:37 PM   #2
Chris
Administrator
Chris's Avatar
Liked 931 Times on 786 Posts
Likes Given: 67
CPVC is mainly a hot water pipe and should not expand or contract any more then regular PVC pipe does. From what I have read it just holds up better over time with the heat then regular PVC pipe. I actually use it for sewer pipe on a few of my jobsites in the renewable energy departments and have not experienced any problems even where it mates up with the manholes. Another question is why are you using this over copper or poly?
Chris is offline
Old 09-28-2011, 09:23 PM   #3
Mr_David
Easily Amused
Mr_David's Avatar
Liked 895 Times on 726 Posts
Likes Given: 593
I've notice here on the forum that they use a lot of PVC/CPVC inside for domestic water systems Hot and cold.
Typically here it's used for in the ground service and irrigation.
a.k.a. Krazedav
Mr_David is offline
Old 09-28-2011, 11:44 PM   #4
phishfood
Administrator
Liked 965 Times on 775 Posts
Likes Given: 1739
I have used CPVC for the shower head riser on many occasions, and so far have had no issues with it. Copper does provide a little more rigidity for the shower arm, though.
phishfood is offline
Old 09-29-2011, 03:44 PM   #5
burchis
Thanks for your reply phishfood.
I thought about creating a flexible loop between the faucet and shower head. Basically build a "U-shape" supply. i.e. From the faucet- run a 4" horizontal and then 90 up to another 4" horizontal back to the shower head.
Another option would be to use a 24" flex hose connected between the faucet and shower head.
Anyone else have any ideas?
burchis is offline
Old 07-10-2014, 04:57 PM   #6
barnabas1969
Established Member
I always use rigid copper between the faucet and the drop elbow for the shower head. It's much stronger and resists breakage due to someone pulling (or whatever) on the shower head.
barnabas1969 is offline
Old CPVC test phishfood Plumbing Products 19 09-19-2012 11:18 PM
Cpvc- how does one KULTULZ General Plumbing Help 6 11-02-2011 06:55 AM
SCH 80 CPVC with SCH 80 PVC Fittins Chris General Plumbing Help 4 11-02-2011 12:54 AM
Copper or PVC or CPVC, oh my! AJay General Plumbing Help 15 07-24-2011 02:39 PM
Newest Threads
