Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Water Heaters and Softeners > Flushing the water heater.
Thread Tools Display Modes
Old 01-05-2010, 10:21 PM   #1
rustywrangler
Default Flushing the water heater.
We have hard water here and I was advised that I should "flush" my water tank every few years to go about cleaning out sediment.
Can someone explain this process? It will be on a less than 5 yr old "12 Year GE 50 gal."
rustywrangler is offline
Old 01-05-2010, 10:49 PM   #2
Chris
Administrator
Chris's Avatar
Liked 567 Times on 497 Posts
Likes Given: 46
The way I do it is to hook up a hose to the hose spicket and just open the valve and the crud just shoots out with the water but things may be different in NY.
Chris is offline
Old 01-05-2010, 11:18 PM   #3
rustywrangler
Quote:
Nope, I have the spicket as well. Do I open the upper valve also, or do you just let it drain???
Old 01-05-2010, 11:57 PM   #4
Chris
Administrator
Chris's Avatar
Likes Given: 46
Just hook up a hose to the spicket and open it up and let it drain. don't open any other valve.
Chris is offline
Old 01-06-2010, 12:19 AM   #5
'Cause
My drains are stopped up
'Cause's Avatar
Liked 1 Times on 1 Posts
Rusty, just open the bottom drain and let the city water pressure flush it out. I'd do this about twice a year, no need to Drain it all just let it flush out for couple of minutes.
'Cause is offline
Old 01-06-2010, 02:24 AM   #6
rustywrangler
Quote:
City water is at about 60 PSI so that would do the trick.
Old 01-06-2010, 04:19 AM   #7
Ktx7ca
HI did you go with gas fired or electric?
Ktx7ca is offline
Old 01-06-2010, 09:00 AM   #8
rustywrangler
Quote:
Gas, partially because my breaker box is full and would not accept another breaker and partially because the one before was Gas.
Old 01-07-2010, 03:00 PM   #9
majakdragon
On the newer tanks, there are back-flow devices that make it necessary to open the Temperature/Pressure relief valve to drain the tank. What I do is the following. Turn off the unit (if electric) or set to pilot if gas. Turn off the cold water supply valve at the top of the tank. Open a hot water faucet near the tank. Attach the hose to the drain valve and run the hose where you want it to drain. Open the drain valve and let all the water drain that will drain. carefully lift the lever on the T/P valve and see if more water drains. Once you have the tank drained, open the cold water supply valve for a minute or two. Watch the water coming from the hose to see if debris is still coming out. Once the water is running clear, you can close the valve and refill the tank. My reason for totally draining the tank is that much debris is sitting on the bottom of the tank. With the tank empty, the pressure from the dip tube will be higher and directly onto the tank bottom. This cleans it more effectively.
majakdragon is offline
Old 01-09-2010, 01:27 AM   #10
JWPlumbing
What I tell customers is get a washing machine hose or a longer hose if needed hook it up to the drain cock on the heater and run it to the floor drain in the mechanical room. When you change out the filter on the furnace just turn on the the drain cock change the filter and turn off the drain cock. If you do this once a month you will save yourself alot of problems. DON'T touch the T&P valve if you do it may start leaking and will then need to be changed. The city pressure will be more than enough pressure to clean your tank properly.
JWPlumbing is offline
Tags
water heater, clean out, flushing, drain, sediment
Toilet doesn't refill after flushing? tflo77 Toilets and Sinks 9 06-17-2012 02:43 AM
Toilet Flushing psk09 General Plumbing Help 1 10-12-2011 09:18 PM
Water in bowl rises before flushing msr1015 General Plumbing Help 4 09-13-2011 05:34 PM
Flushing Toilet clogged + spews water out of bathtub? udt123 Drain and Sewer Cleaning 2 06-21-2011 02:00 PM
Flushing Sound malkee General Plumbing Help 10 07-03-2010 02:51 PM
