Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Toilets and Sinks > Toilet keeps running
Thread Tools Display Modes
Old 08-02-2011, 07:09 PM   #1
hunters
Liked 1 Times on 1 Posts
Default Toilet keeps running
I hope someone here may be able to help me not have a plumber come out for what may be a simple service call. My toilet has started to run well after being flushed. What I've done successfully to stop it from running is by gently lifting a small black vertical "lever" for a second as illustrated by the attached image. I can provide more info if needed, but I don't know what else to provide yet. Thanks for any help!
hunters is offline
Old 08-02-2011, 08:10 PM   #2
havasu
Administrator
havasu's Avatar
Liked 1130 Times on 922 Posts
Likes Given: 350
To repair your toilet, you might only have to adjust the float a bit to ensure the water stops flowing. These do wear out, and if this is the case, go to your local big box hardware store and look for a Fluidmaster 400a, or similar, for about ~$8.00, and install a new one. Follow the instructions, and it should take about 10 minutes before your toilet is up and running (or in this case, not running!) again.
havasu is online now
Old 08-03-2011, 01:52 PM   #3
hunters
Thank you for your reply. Sorry for the stupid question, but can you give me any insight to adjusting the float?
hunters is offline
Old 08-03-2011, 01:53 PM   #4
GregC
Quick Belt System
Also try below the TOP Red cap there, it should twist off counter clock wise and there should be a replaceable black gasket under there. It could have something inside there stopping it form sealing or it could be worn out. Try to flush it out, or clean it or even replace it. Another thing, make sure the Black float is full of water, hold it down under the water level to fill. Sometimes air is inside that black float and it will not rise properly. Hope this helps.
GregC, President/Founder www.Quicktoolbeltsystem.com
GregC is offline
Old 08-03-2011, 01:58 PM   #5
havasu
Administrator
havasu's Avatar
Likes Given: 350
On your picture, you have a white line indicating "lifting here stops it". What you are pointing at can be turned with either your fingers or a phillips screwdriver. Turning that knob will push the float farther into the water, causing more pressure to be placed on the valve to stop the water completely. Also, please don't apologize. Every person reading this forum has been in this position at one time or another, and we here are happy to help!
Old 08-04-2011, 09:35 PM   #6
hunters
Thanks for the tips all. This weekend, I'm going to do something about it. Will report back. Thanks again!
hunters is offline
Old 08-05-2011, 12:16 AM   #7
caffeineaddict
you could also turn the water off to the toilet and along the tube for the fill valve before it gets to the float you'll notice a little ring (you can see it on the picture above that Havasu posted that's kinda in the middle). you can slide that up and it'll allow you to move the top tube up and down to adjust the water level in the tank as well as the rod you can screw up and down. just make sure you got that ring back down all the way back on before turning the water back on to your toilet. Or otherwise the top half of your fill valve will shoot out of the tank like a little rocket =)
caffeineaddict is offline
toilet vent running horizontal alainmax Plumbing Building Code 11 06-17-2011 06:05 PM
Water constantly running in toilet ihavezippers General Plumbing Help 4 05-19-2011 05:25 AM
Running Kohler Toilet orfeo Toilets and Sinks 4 05-08-2011 07:27 AM
Toilet running purbrookian Toilets and Sinks 12 04-12-2011 07:57 PM
Toilet keeps running. NEED HELP! lowlevelowls General Plumbing Help 5 09-27-2010 12:33 AM
Newest Threads
