Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Drain and Sewer Cleaning > Kitchen sink running out roof overflow
Thread Tools Display Modes
Old 07-20-2011, 04:07 PM   #1
scott
Default Kitchen sink running out roof overflow
I have a clogged kitchen sink that is becoming a nightmare. I removed the disposal and pipes under the sink. I ran a snake roughly 25ft and all seemed clear. Now when I run the water and disposal its coming out of the roof overflow pipe. I ran out of snake. Does this mean that I have a clog further down? Any suggestions?
scott is offline
Old 07-20-2011, 04:26 PM   #2
havasu
Administrator
havasu's Avatar
Liked 1114 Times on 906 Posts
Likes Given: 336
Time to either get a longer snake, or call someone with one. Are you certain you were guiding the snake down the drain towards the blockage and not up the air vent?
havasu is offline
Old 07-20-2011, 04:30 PM   #3
scott
When running the snake it would clear and then block again after another foot or so. Then it really opened up for the last 10 feet or so and I thought I was home free. When I couldn't get the water to stop coming back up through the disposal then I realized the water coming up the air vent. Thanks for the response!
scott is offline
Old 07-20-2011, 04:47 PM   #4
havasu
Administrator
havasu's Avatar
Likes Given: 336
There are many things that I will do myself, but snaking a main line is not one of them. You really need to know how to operate the snake properly and have a feel for what the snake is doing. They also can cause serious injuries if you are not paying close attention.
havasu is offline
Old 07-20-2011, 05:01 PM   #5
scott
I think you were correct on going up the vent. Giving it another shot and if it doesn't work then I'll call a pro. I'm using an old hand snake with a vice grip for leverage. Not dangerous, just hard to get the feel you mentioned. Thanks again for the advice!
scott is offline
Old 07-20-2011, 05:07 PM   #6
havasu
Administrator
havasu's Avatar
Likes Given: 336
Turn on the nearest faucet to a slow stream which will help guide the snake in the correct direction.
havasu is offline
Old 07-21-2011, 01:34 PM   #7
johnjh2o
johnjh2o's Avatar
Liked 722 Times on 546 Posts
Likes Given: 615
Quote:
Scott I don't understand how your getting water coming out of the roof vent, that you call a overflow. It would have to overflow the sink long before it reached the roof height.
John
johnjh2o is offline
Old 07-24-2011, 02:32 AM   #8
Mr_David
Easily Amused
Mr_David's Avatar
Liked 869 Times on 706 Posts
Likes Given: 577
Have any pictures . As John mentioned that is pretty odd sounding.
a.k.a. Krazedav
Mr_David is offline
Old 08-07-2011, 02:42 PM   #9
Fansplumbing
Master Plumber
He must be talking about a air admittance valve installed under the counter. If not, I'd like to see it!
Fansplumbing is offline
Old 10-09-2011, 08:55 PM   #10
chris2011
Default water out roof
I just had the same thing happen to me. Stupid, I put carrot tops down the disposal. I was trying the plunge the drain when my husband came in and said there was water & carrot tops coming out the roof. Crazy.... I can't get the drain to open up. Will have to call a plumber in the morning. Which drain should I make sure he has access too?
chris2011 is offline
Is there a better way to tie in the Kitchen Sink? flannag General Plumbing Help 16 01-08-2012 01:21 AM
How do seal the bottom of the sink/plastic overflow outlet on an enameled steel lava stouto General Plumbing Help 4 12-25-2011 12:28 AM
looking for help with kitchen sink heebie Drain and Sewer Cleaning 5 07-25-2011 01:22 PM
EZ way to clear slow running bathroom sink drains without a wire snake. 5shot Drain and Sewer Cleaning 12 05-15-2011 01:50 AM
Kitchen sink drains extremely slowly and backs up (double sink) TimeForAction General Plumbing Help 6 10-22-2010 07:46 AM
Newest Threads
