Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Showers and Tubs > Please help, shower leaking under toilet have tried everything!
Thread Tools Display Modes
Old 06-13-2011, 04:21 PM   #1
kinnz03
Default Please help, shower leaking under toilet have tried everything!
I am in need of some advice, first it started with a slow drain in my shower, then water comes under the toilet when showering, we have snaked out the main drain line, nothing major came out, (lots of crud) the only thing backed up in my house is the bathroom! So we thought we had it fixed, then when flushing the toilet the clean water (its all clean nothing nasty that leaks) that fills the tank comes out on the floor:
Replaced wax ring, snaked toilet, snaked and flushed out the pipe that leads to the tub, it worked great thru 7 showers, then the water again coming out from under the tub. I am at a loss for what the issue could be now? I have ripped the wall out of my kitchen to gain access to the shower we snaked it shot water thru the pipe and thats when it seemed to work only to mess up again, we have an older house. HELP!
kinnz03 is offline
Old 06-14-2011, 12:05 AM   #2
Caduceus
Caduceus's Avatar
Liked 350 Times on 255 Posts
Likes Given: 230
When you say that "then the water again coming out from under the tub" do you mean that the tub is backing up again? If so, the line may need to be cleared more thoroughly. How far did you go with the snake and what size snake did you use?
Caduceus is offline
Old 06-14-2011, 12:09 AM   #3
phishfood
Administrator
Liked 965 Times on 775 Posts
Likes Given: 1739
It sounds as though you have something in the pipe that is collecting debris and causing repeated clogs. It is also possible, particularly if you have cast iron pipe, that the pipe is rotted through and dirt is getting in and causing your problem.
phishfood is offline
The building assume my toilet leaking... cooper General Plumbing Help 16 05-03-2012 06:12 PM
leaking wax ring on my toilet cybermut2000 Toilets and Sinks 6 04-29-2012 01:03 AM
Toilet fill valves leaking jwwing General Plumbing Help 4 01-15-2011 05:58 PM
toilet leaking? michaelooch Toilets and Sinks 1 10-14-2010 12:28 AM
toilet leaking into overflow pipe bridgeboy Toilets and Sinks 17 02-27-2010 07:06 AM
Newest Threads
