kennyrogers
For years I was always under the assumption that each hot water return line needed it's own dedicated pump to the water heater. If you have two separate lines... you would need two pumps. I've seen some other plumber's work and they had two lines teed together before the single pump, check valve, then to the cold side.
It makes sense that it would work on the return part of the line, but doesn't sit right on the hot going to the furthest fixture part. Any ideas?, thanks.
