Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Low water pressure
Thread Tools Display Modes
Old 06-05-2011, 04:14 PM   #1
spud91854
Default Low water pressure
I live in Mexico and have low water pressure. Need economical way to boost pressure with pump and tank. Any suggestions?
spud91854 is offline
Old 06-05-2011, 05:52 PM   #2
joesplumbing
Banned
You sorta answered your own question. What you need is a booster system. Amtrol makes a decent one here...
Amtrol- Pressure Booster Systems
joesplumbing is offline
Old 06-06-2011, 06:33 PM   #3
speedbump
Wells & pumps; not a...
speedbump's Avatar
Liked 164 Times on 150 Posts
Likes Given: 40
Well water or city water?
speedbump is offline
Old 06-07-2011, 02:10 PM   #4
spud91854
City Water
Old 06-07-2011, 02:11 PM   #5
spud91854
City water here
Old 06-07-2011, 02:46 PM   #6
speedbump
speedbump's Avatar
Likes Given: 40
There are many ways to boost pressure. A simple 1/2hp jet pump with a flow switch will turn it on and off.
Old 06-08-2011, 01:19 AM   #7
Caduceus
Caduceus's Avatar
Liked 348 Times on 254 Posts
Likes Given: 230
I have to ask what your water pressure is. This is only because I have come across customers who think that their pressure is low compared to a previous home or a friend/relatives home and it turns out that everybody's pressure was high. It could also be a matter of volume, not pressure, depending on what your situation is. Your house pressure should be 45-65 psi depending on house and piping design. Lower than 45 psi may give poor performance and over 75 psi could cause damage to a variety of things on your plumbing system.
If you are on city water, do you have a regulator? If so, it could be bad or just needs to be adjusted.
Caduceus is offline
Old 06-10-2011, 02:39 PM   #8
spud91854
The problem here is that at times the town reduces the pressure so much that the water will not reach the house
because I am on a small hill. Most people use a water tank and pump so the water trickles into the tank from the street and the pump moves it up the hill. The problem is that sometimes I am afraid that the Water tank(Tinaco)
will run dry and burn up the pump.
Thanks
Old 06-10-2011, 03:11 PM   #9
speedbump
speedbump's Avatar
Likes Given: 40
You can put a float in the tank that will turn the pump off when the water level is too low. It's not that costly and works well.
T-ing Two Water Supply Lines for Greater Water Pressure JZeld General Plumbing Help 15 03-12-2012 08:13 AM
water pressure sky rockets when water heater is on jfrisby General Plumbing Help 2 02-16-2012 03:45 PM
Cold water pressure lower than hot water Va_guy General Plumbing Help 3 07-11-2011 12:50 AM
Water Pressure 110-120 PSI - My problem or the water co's? WillJohnston General Plumbing Help 11 03-18-2011 12:55 PM
Newest Threads
