Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Need help with kitchen sink disaster.
Thread Tools Display Modes
Old 06-04-2011, 04:10 AM   #1
distraught22
Default Need help with kitchen sink disaster.
I noticed a small pole of water leaking from under my cabinet today. I opened it up only to see giant puddles of black water everywhere. My pipe had burst and it was a huge mess.
So I go down to the hardware store to get some parts, and they gave me a P-Trap (I think I'm saying that right, the pipe that looks like a backwards J), a wrench, and some putty. I go home and attempt to install the new P-trap. The left hand bolts come off fine, but when I go to remove the right hand ones, EVERYTHING CRUMBLES!
I couldn't believe what happened, I didn't mean to make things worse. Now the pipe that was connecting to it is totally destroyed as well and I don't know what to do. I am terrified and I don't want to live like this. What do I have to do? Please help me.
distraught22 is offline
Old 06-04-2011, 04:15 AM   #2
Hyper48fan
Liked 1 Times on 1 Posts
loosen up the nut close to the wall(that nut connects the trap arm to the drain). When you purchased the p-trap it should have came with the belly, the trap arm (together they make a p shape) and nuts.
Hyper48fan is offline
Old 06-04-2011, 04:19 AM   #3
Hyper48fan
I was looking at the last picture...loosen up the chrome nut before the 45 degree fitting and pull out the broken piece. Be careful, it may be hard to pull out, I don't want you to slip and cut yourself on the broken piece.
Old 06-04-2011, 04:23 AM   #4
distraught22
I keep trying to get a grip on that nut with my wrench but it won't stay on.
It keeps slipping and shaking.
I've never done this before and I'm afraid if I apply too much pressure it'll make things even worse.
Old 06-04-2011, 04:35 AM   #5
Hyper48fan
If you're using channel locks don't grip it too tight. Too much grip will work against you with these nuts.
Old 06-04-2011, 04:39 AM   #6
Hyper48fan
lefty loosy righty tighty
Old 06-04-2011, 04:43 AM   #7
Hyper48fan
you might try to heat up that joint if you can't get it with channel locks (slip joint pliers) a lighter might just do the job...it's unconventional but it might just work.
Old 06-04-2011, 12:28 PM   #8
SlowDrip
Plumbing Sales
SlowDrip's Avatar
People tend to use too much pressure on those nuts. You could try one of those rubber strap wrench thingies that people keep around for opening jars. I find they are pretty useful for amateur plumbers because they stretch instead of crimping.
It could be that the joint is gummed up with calcium. A bit of PB blaster or some vinegar might help loosen it.
SlowDrip is offline
Old 06-05-2011, 05:31 AM   #9
Another-Plumber
Another-Plumber's Avatar
Liked 6 Times on 5 Posts
Likes Given: 4
i would have that fixed in 5 mins, no matter what
Another-Plumber is offline
Old 06-05-2011, 05:33 AM   #10
joesplumbing
Banned
That's why people hire plumbers. If you're too afraid to do it yourself, hire a plumber. This is an easy fix and shouldn't cost too much if you shop around.
joesplumbing is offline
Avoided a near disaster - Is there a solution so it doesn't happen again? greggor36 General Plumbing Help 15 07-22-2012 09:32 PM
Bathtub Drain Disaster, Please Help! abbyhope Showers and Tubs 1 07-07-2012 01:59 AM
Is there a better way to tie in the Kitchen Sink? flannag General Plumbing Help 16 01-08-2012 12:21 AM
looking for help with kitchen sink heebie Drain and Sewer Cleaning 5 07-25-2011 01:22 PM
Kitchen sink drains extremely slowly and backs up (double sink) TimeForAction General Plumbing Help 6 10-22-2010 07:46 AM
