Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Washing machine sends plumbing all out of whack!
Thread Tools Display Modes
Old 05-30-2011, 09:06 PM   #1
MeKaDi87
Default Washing machine sends plumbing all out of whack!
Hi,
I just moved into a home that has had everything completely redone. The seller of the home claims that all of the plumbing has been redone as well. I'm having a problem with the washing machine backing up into the kitchen sink, and causing the toilet to bubble as well. Then a few minutes later, water will leak from what seems to be the bottom of the water heater. It's not coming from the valve/tube. I have no idea what is causing this problem. Any help will be greatly appreciated! Thank you!
MeKaDi87 is offline
Old 05-31-2011, 12:33 AM   #2
Caduceus
Caduceus's Avatar
Liked 350 Times on 255 Posts
Likes Given: 230
You may have a floor drain under your hot water tank that is backing up. Look under it, if you can to see if that is the case. With the type of back up you have described, you need to have the main drain line cleared and cleaned.
Caduceus is offline
Old 05-31-2011, 11:49 PM   #3
Dr-Copper
Dr-Copper's Avatar
Caduceus is right. A floor waste is more than likely to be underneath the hot water heater. Other than that , it is a CLASSIC blocked drain.
You need to get it cleared
DC
Dr-Copper is offline
Old 06-02-2011, 04:02 AM   #4
MeKaDi87
Thanks. I did a little more investigating and realized that it wasn't the water heater leaking, but a pipe behind it that was supposed to be a drain for the condensation from the A/C, or something like that. I had plumber come out today, and he said the same thing. He suspects that since my house sat for a considerably long time before it was remodeled that roots could have possibly grown in the main drain. He's bringing an auger (sp?) tomorrow to hopefully clear the line. It will be nice to have functioning indoor plumbing again !!!
THANKS FOR YOUR HELP!
MeKaDi87 is offline
Old 06-02-2011, 11:10 PM   #5
Dr-Copper
Dr-Copper's Avatar
Its a pleasure.
good luck with it .
d
Old 06-26-2011, 03:43 PM   #6
MeKaDi87
Okay, guys, I'd really appreciate your help again. I had a some plumbers come out and clear my main drain- but water still keeps backing up. Any other suggestions of what could possibly be the problem?
MeKaDi87 is offline
Old 06-26-2011, 05:57 PM   #7
Mr_David
Easily Amused
Mr_David's Avatar
Liked 868 Times on 705 Posts
Likes Given: 577
Did the plumber check his work.
Maybe he just didn't do a good job.
You could have a secondary stoppage that he failed to check for.
a.k.a. Krazedav
Mr_David is offline
Washing Machine Won't Drain Stella General Plumbing Help 3 04-18-2012 08:47 PM
washing machine question topcop1000 General Plumbing Help 1 10-29-2011 01:57 PM
Washing machine plumbing nickb7 General Plumbing Help 10 07-28-2010 05:01 PM
Running tab when washing machine is on ahoff General Plumbing Help 1 06-18-2010 04:30 PM
Loud Washing Machine? Conway General Plumbing Help 3 01-14-2010 07:47 PM
Newest Threads
