Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Plumbing Building Code > Adding three sink to washer drain
Thread Tools Display Modes
Old 04-17-2011, 11:52 PM   #1
vaportx
Default Adding three sink to washer drain
Attached are two pictures for existing plumbing to the washing machine and crude picture of adding three new drains for three additional sinks.
Click image for larger version
Name:	IMG_1081 (Medium) - Copy.JPG
Name:	three new drains with vents - Copy (Medium).jpg
We need to add one hand sink, one mop sink and one large 3 compartment sink.
Any advice or recommendations if this would meet building codes in Texas and if there is a simpler way.
Adding new Y connector and moving existing washer drain up higher to make room for drains running underneath.
Use existing Y connector for hand sink
Adding new Y connector below for mop sink
Adding new Y connector at bottom for large 3 compartment sink
All three sink, hand sink, mop sink and 3 compartment sink will have vent tied into to existing roof vent using T connector
Washer drain since at top of stack will continue to use root vent
Questions:
I assume each drain must be separated?
Are separate vents needed for each of the drain lines?
Is it ok to use T connector for the vents where they connect to drain?
For the drains close to the bottom of the floor, is there a minimum height for the drains to be above the floor?
The Y connector at the main drain pipe, is it ok to stack four Y connectors?
With this many drains running into one pipe is there a minimum size the drain must be?
Is there a simpler way to design this and meet building codes?
vaportx is offline
Old 04-18-2011, 12:50 AM   #2
Caduceus
Caduceus's Avatar
Liked 350 Times on 255 Posts
Likes Given: 230
What is this for? A commercial kitchen or restaurant? When you say "mop sink" do you mean laundry tub? Also, it already appears that you will exceed the recommended volume for the 2" pipe (vertical fixture units).
Caduceus is offline
Old 04-18-2011, 02:57 AM   #3
vaportx
Yes, commercial kitchen, we need to add three sinks, hand sink, mop sink and large 3 compartment sink.
Do you see any way we can make this work?
I am not familar with building codes, is the exceed recommended volume for 2" pipe a recommendation or something that will fail build codes?
vaportx is offline
Old 04-19-2011, 12:02 AM   #4
Caduceus
Caduceus's Avatar
Likes Given: 230
As far as my codes are concerned, no, it won't work the way you want it to. Primarily, where is your grease trap? The proper pipe size and installation is a code requirement and believe me when I tell you that you don't want to run a commercial kitchen that is not piped properly. It's best to get somebody on the job sit to make a recommendation.
Caduceus is offline
Old 04-19-2011, 12:13 AM   #5
LiQuId
Liked 15 Times on 11 Posts
Likes Given: 20
Hire a plumber, there are many codes that you need to know about... not second hand stuff, you need to KNOW how to run this piping. 2" drain, too little, no grease trap, wrong piping type ( inmortant to use the right kind in commercial drain ). andBeing that Im also a gasfitter I suppose its worth saying that you NEED to hire one of us to make sure you dont have mega problems with your intake air and ehaust hoods.
LiQuId is offline
Old 04-19-2011, 02:48 AM   #6
Mr_David
Easily Amused
Mr_David's Avatar
Liked 895 Times on 726 Posts
Likes Given: 592
I agree. That won't work. That's what you call wet venting and not recommended.
Nice cut and paste job though.
a.k.a. Krazedav
Mr_David is offline
Old 04-19-2011, 11:45 AM   #7
lordofthepipes
wow, that is some ugly work.
lordofthepipes is offline
Old 04-20-2011, 12:01 AM   #8
Caduceus
Caduceus's Avatar
Likes Given: 230
Yep. Could have skinned that cat differently.
Caduceus is offline
Old 05-14-2011, 11:51 PM   #9
Another-Plumber
Another-Plumber's Avatar
Liked 6 Times on 5 Posts
Likes Given: 4
OMG, that looks like a mess... you know what they say, if it not pretty its WRONG
Another-Plumber is offline
Old 05-14-2011, 11:53 PM   #10
Another-Plumber
Likes Given: 4
Quote:
lol
Now thats funny
Adding a washer drain to main drain stack.... phantomvs General Plumbing Help 10 07-22-2012 12:18 AM
Washer and Sink drain dsell General Plumbing Help 6 04-01-2012 01:58 PM
New utility sink + washer drain line brownetowne Toilets and Sinks 0 06-26-2011 10:42 PM
How to add Utility Sink and Washer Drain to existing drain stack obriendigital General Plumbing Help 1 03-27-2011 02:15 AM
Adding a sink artaman General Plumbing Help 5 03-02-2010 03:32 PM
Newest Threads
