Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Prepping for winter?
Thread Tools Display Modes
Old 01-13-2010, 03:43 PM   #1
mikej
Default Prepping for winter?
I live in south Texas and it just started hitting freezing to where I have to wrap my faucets. Is there anything I should do for my automated watering system? I've had it off since late fall but now that I'm thinking about it couldn't the water in those pipes freeze too?
mikej is offline
Old 01-13-2010, 09:51 PM   #2
Conway
Conway's Avatar
Liked 1 Times on 1 Posts
Good question. I never thought about it. Have you gone back and reviewed the instruction manual?
Conway is offline
Old 01-14-2010, 01:03 PM   #3
majakdragon
Sprinkler systems should be drained when turned off for the season.
If you have never made a mistake, you probably haven't done much.
majakdragon is offline
Old 01-14-2010, 07:59 PM   #4
mikej
I tried to find out how to do it but I can't even find the manual online. Any body here know hot to drain one?
mikej is offline
Old 01-14-2010, 08:35 PM   #5
havasu
Administrator
havasu's Avatar
Liked 1058 Times on 854 Posts
Likes Given: 290
Many irrigation lines can be drained by going to the lowest point of your irrigation line, and removing the sprinkler. You would then need to break the seal at the valve to allow air into the lines. I've also heard you can use an air compressor by forcing air into the line, but again, the valve would need to be opened fully to bleed out any excess water.
havasu is offline
Old 01-15-2010, 06:34 PM   #6
irrig8
Quote:
I had this whole thing typed up, step by step and I accidentally hit the back button.
Try this:Winterizing Your Irrigation System
If you need more help, I'd be more than happy to assist.
irrig8 is offline
Old 01-21-2010, 04:17 PM   #7
speedbump
Wells & pumps; not a...
speedbump's Avatar
Liked 182 Times on 165 Posts
Likes Given: 43
Most folks use an air compressor to blow them out. It's not full proof, but it will get most of the water out in most cases.
speedbump is offline
Old 06-01-2010, 06:27 PM   #8
donald1
Quote:
yes he sounds real.
donald1 is offline
Old 10-29-2011, 02:56 PM   #9
DCPlumber
I winterize/drain approximately 225 houses each Fall. I also winterize a dozen or so lawn sprinkler systems. I tow a 4 cylinder diesel air compressor behind my work van and hook on to the main water line that feeds the sprinkler system. All of the sprinkler systems in our area of Rain Bird systems. There is a setting labeled "test all valves". It opens each zone for 2 minutes while I apply a lot of air volume, not just pressure. I go through the cycle three times. In ten years, I've never had a sprinkler system freeze and break, and it gets down to -15 degrees F here. I'd say it is fool proof if it is done correctly. I can blow out a 10 zone system, including travel time in about 1.5 hours. Fairly inexpensive to the average homeowner that afford a 10 zone system.
DCPlumber is offline
Old 03-16-2012, 03:08 PM   #10
cswanson
The air compressor method is probably the best way to go about forcing the water out.
Chris Swanson, Advanced Irrigation
Minneapolis Sprinkler Systems
cswanson is offline
Tags
outdoor watering, sprinklers, winter prep
RE: Tank not heating water during winter choc-holic Water Heaters and Softeners 7 10-12-2012 06:05 PM
Winter, Pipe ndowens General Plumbing Help 1 12-17-2010 01:03 AM
Winter questions turtlerace General Plumbing Help 6 01-13-2010 03:39 PM
Newest Threads
