Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Plumbing Products > Pex in cold weather.
Thread Tools Display Modes
Old 03-26-2011, 11:02 PM   #1
Dimeblack1
Default Pex in cold weather.
PVC water line in up north cabin burst. Will PEX hold up better in cold weather?
Dimeblack1 is offline
Old 03-27-2011, 01:48 AM   #2
phishfood
Administrator
Liked 964 Times on 775 Posts
Likes Given: 1739
I have heard that it will, but I have no personal experience to prove or disprove that.
phishfood is offline
Old 05-20-2011, 07:27 PM   #3
plumbernyc
Liked 1 Times on 1 Posts
PEX can usually withstand freezing.
How to prevent water from freezing inside the PEX pipes?
plumbernyc is offline
Old 05-22-2011, 09:05 PM   #4
XxGiNoO
you could go with a type of plastic pipe called wirsbo it will expand three times it normal size without bursting and then return to its normal size once thawed price is competitive with pex just cant be in direct sun light and normal rings and crimpers will work
XxGiNoO is offline
Zanne Likes This
Old 05-22-2011, 09:24 PM   #5
havasu
Administrator
havasu's Avatar
Liked 1114 Times on 906 Posts
Likes Given: 336
If I am not mistaken, it is the connectors that usually end up bursting when dealing with PEX. I have no personal knowledge of this, but many plumbers in the mountains have mentioned it to me.
havasu is offline
Old 06-04-2011, 06:08 AM   #6
Hyper48fan
Liked 2 Times on 2 Posts
There are different 'types' of Pex tubing (A, B, C). Pex A (wirsbo) will expand as stated earlier. I'm in Oregon and we use Wirsbo for most residential applications and I've installed up to 2" Wirsbo in really cold weather, it's harder to work with and it takes longer to shrink back on the fittings. Using a torch lightly on the rings will shrink them quickly so you can turn the water on sooner. I've yet to see or hear of Wirsbo freeze breaking but I'm sure it can happen under extreme conditions. The fittings and collars(rings) are the weakest link in the Wirsbo System. Rehau is a great product as well, expensive though.
Hyper48fan is offline
Zanne Likes This
Old 06-04-2011, 06:19 AM   #7
Hyper48fan
Also, I used to work for a small resy company who used "RTI" or "Zurn Pex". It's a quick to install system but we had several issues with the crimp rings. Sometimes the broke or didn't crimp right. Not to mention they are "insert fittings" and neck down the inside diameter of the pipe, creating a large restriction (friction loss). How they are legal...I can only assume they lobbied hard...$$$
Old 06-10-2011, 03:35 PM   #8
tbart16
I use wirsbo all the time I actually had a house freeze this year with it and the only leak was where the home owner used a torch to try and thaw the pipe they actually melted it, otherwise house was froze solid for a few days no wirsbo breaks
tbart16 is offline
Old 06-19-2011, 02:16 AM   #9
AllAces777
AllAces777's Avatar
All pex pipes have a better expansion ratio then metal pipes. Of course Wirsbo is probably the best choice due to the fact that the product installation is based on contracting back to original shape. This is due to Wirsbo being a cross linked polyethylene product. As others have stated though, the fittings will definitely freeze and break in certain conditions. You should insulate the lines or where the weather is extremely cold, heat trace any exposed lines.
If I had my life to live over again, Id be a plumber.
- Albert Einstein
╬-AllAces Plumbing of Las Vegas, Nevada-╬
AllAces777 is offline
Zanne Likes This
Old 06-19-2011, 01:12 PM   #10
Second2None
Pex will withstand freezing better than most......Just dont put your fittings close together......if you do the pex will not have enough room to expand and will/could fail.
Second2None is offline
What's the weather like where you are? Chris General Discussion 933 10-01-2014 07:21 PM
shower temp goes hot cold hot cold kawi027 General Plumbing Help 8 04-24-2012 08:10 PM
Hot when it should be cold Bring Pumps and Wells 4 04-12-2012 11:42 PM
Re. The terrible weather & flooding in the southern u.s. CHRISM General Discussion 7 05-20-2011 10:38 AM
Hot or Cold? fisselt General Plumbing Help 8 08-26-2010 10:01 PM
Newest Threads
