Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Water Heaters and Softeners > hot water heater on concrete floor
Thread Tools Display Modes
Old 03-09-2011, 03:47 PM   #1
kathymc7719
Default hot water heater on concrete floor
I have a hot water heater that was installed about 2 years ago. The new hot water heater has a metal bottom that sits directly on the concrete floor of my basement. The previous hot water heater had about 2 inches of air space between the bottom & the concrete floor.
I am concerned about the life of the water heater since it seems that it is more likely to rot the bottom out without any air circulation below the heater. There is also the concern that there is heat bleeding going on with the heater sitting directly on the floor.
When this new hot water heater was replaced the plumber told me that the newer heaters only have a life of about 10-12 years as compared to the hot water that I replaced that was 22 years old. So is this planned obsolesence?
I have a plumber coming into to do a bathroom remodel next week & wondering if it is worth it for me to have him raise this hot water heater up so that it is about 2 inches off of the floor?
Thanks
kathymc7719 is offline
Old 03-10-2011, 03:09 AM   #2
DUNBAR PLUMBING
MASTER PLUMBER
DUNBAR PLUMBING's Avatar
Liked 11 Times on 9 Posts
If it is a GE Gas Water Heater, then there is no harm with the heater setting on the floor in that design.
If it is electric, I'd get it up on some type of elevation.
Plumber is correct, you'll never get the lifespan out of your water heater, and the amount of wasted energy you spent on your 22 year old heater could of bought 3 heaters plus labor.
Thanks
DUNBAR PLUMBING is offline
Water main coming in through concrete pad bdanwallin General Plumbing Help 1 04-20-2012 12:40 PM
Replace toilet on uneven concrete floor 3_Fathom_Harbour General Plumbing Help 1 08-09-2011 01:09 AM
Water in concrete sump escaping through cracked hole in side. Dimeblack1 General Plumbing Help 0 03-23-2011 02:04 AM
Bathtub Drain in a concrete slab floor NTLBM Showers and Tubs 5 01-12-2011 09:24 PM
Floor coating for concrete shower floor reprosser Showers and Tubs 14 07-31-2010 03:16 AM
Newest Threads
