Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Freezing/Scalding showers
Thread Tools Display Modes
Old 03-03-2011, 04:30 PM   #1
Jayhawk
Default Freezing/Scalding showers
This is a problem we've dealt with but it's annoying and I want to fix it. We have a 15 year old (we've owned it for a couple of years), somewhat upscale for our area, 3.5 bath home with an issue I've never had before. When one shower is in use, and someone turns on water, flushes a toilet, etc., the water in the shower either goes colder or hotter. Is this a case of the builder using cheap valves, and they need to be replaced to fix the problem? We'll have to open walls to get at them, but I'm perfectly willing to do that if we can make this go away. Thanks for your help.
Jayhawk is offline
Old 03-03-2011, 06:03 PM   #2
SlowDrip
Plumbing Sales
SlowDrip's Avatar
Liked 1 Times on 1 Posts
Yes, your house lacks anti-scald valves which are now code. Replacing them will fix your problem.
SlowDrip is offline
Old 03-03-2011, 11:44 PM   #3
phishfood
Administrator
Liked 964 Times on 775 Posts
Likes Given: 1739
Is this something that just started happening, or has it been a problem the entire time you have lived there?
phishfood is offline
Old 03-04-2011, 02:02 PM   #4
Jayhawk
It has always happened in this home. It just didn't seem like this builder, who is known for building quality homes, would have put these kind of (cheap) valves in the home. But it seems that's what he did. This is the fourth home I've owned over the course of 25 years and have never had this issue.
Jayhawk is offline
Old 03-04-2011, 06:41 PM   #5
SlowDrip
Plumbing Sales
SlowDrip's Avatar
If it has always been an issue then it is defiantly "cheap" valves. 15 years ago many places did not legally require pressure balanced valves, now they are code almost everywhere.
To be fair to the builder (for some reason) most "contractor" series of valves back then did not have pressure balancing built in, and if you are buying dozens of valves you probably don't want to pay more for a fancy picture on the box like you do when buying retail.
SlowDrip is offline
Old 03-26-2014, 03:32 PM   #6
sdseaman
We just purchased a house that was built in 1988 and are experiencing the same scalding / freezing issue when any other water source is used during a shower. The house has the original Moen single handle bath / shower controls. I have one local plumber saying that they are pressure balanced. What was the standard back in 1988? Our last house was built in 1993 and the showers were fine.
I have new faucets but am afraid to install them if it won't correct this issue. Please advise and see the attached pic. From my research, a Posi-Temp and MoenTrol were the two Moen lines of pressure balanced faucets and the faucet shows no reference of this name on it.
sdseaman is offline
Old 03-26-2014, 03:56 PM   #7
johnjh2o
johnjh2o's Avatar
Liked 717 Times on 544 Posts
Likes Given: 610
That is a Moen faucet but it is not anti-scald.
John
johnjh2o is offline
Old 03-26-2014, 06:59 PM   #8
sdseaman
Johnjh20, That was my thought but my plumber of 10 years swears it's a pressure balanced / anti-scald faucet. I'll just replace it and move on. Thanks for your help.
sdseaman is offline
Old 03-26-2014, 07:08 PM   #9
johnjh2o
johnjh2o's Avatar
Likes Given: 610
Quote:
Your plumber of ten years more then likely has never installed a shower valve that is not balance pressure. Balance pressure has been required for more then ten years. I have been doing plumbing for over 50 years and that valve is not a balance pressure valve.
John
johnjh2o is offline
Old 03-27-2014, 12:30 AM   #10
journeyman
the professional
journeyman's Avatar
Liked 142 Times on 111 Posts
Likes Given: 142
John is right that is a moen shower valve. It is not pressure balanced
journeyman is offline
Oasis Platinum Steam showers by Ariel islandgirl Showers and Tubs 7 12-20-2015 07:44 AM
Impey Wetroom and Showers j5payne General Plumbing Help 1 03-18-2011 07:09 AM
Toilets bubbling when showers drain Gatorfreak General Plumbing Help 5 05-07-2010 03:16 PM
no hot water in upstairs showers????? jed General Plumbing Help 1 03-03-2010 11:12 PM
Newest Threads
