Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Rough-in for concrete over PVC DWV
Thread Tools Display Modes
Old 02-28-2011, 08:57 PM   #1
jmprPF
Default Rough-in for concrete over PVC DWV
What is standard practice at the rough-in stage for PVC DWV piping that penetrates a slab floor? In particular, how are vents and drains terminated in (or above or below) the slab before the concrete work is done?
Are all drains/vents brought through the slab and left projecting above the level of the concrete, a foot or so? (Presumably toilet drains are then cut off to finished floor level.) Or is there some standard practice that leaves the piping at or below concrete level at rough-in, and then the piping is extended through the slab after the concrete work and structural framing are completed?
I'm an amateur with some experience with under-slab DWV plumbing but in the past have used what must be non-standard approaches to this question. (I believe I'm adequately informed/experienced with pipe sizing and pipe layouts including under-slab practices, and can satisfy local building codes.)
jmprPF is offline
Old 03-01-2011, 01:04 AM   #2
phishfood
Administrator
Liked 965 Times on 775 Posts
Likes Given: 1739
Water closets a few inches above the concrete, sink, lavatory, and laundry drains and vents ~24" above. The only time I terminate flush with concrete is in types of construction that utilize rollout forms for pouring upper floors.
Under slab rough-in can seem deceptively simple, but it is really easy to screw up. And with layoffs rampant in building departments as local governments try to balance their budgets, don't count on the inspector to catch every issue. If you have a question, do not hesitate to ask us.
phishfood is offline
Old 03-01-2011, 07:07 PM   #3
PrecisionPlumbing
Master Plumber
PrecisionPlumbing's Avatar
all piping needs to be sleeved in plasic where concrete will touch and stubbed 24" above the floor
www.Precision-Plumbing.com
‎(469)-248-2136 Precision Plumbing providing Service Repair Remodels Installing Quality Products With a Best Rate, Best Warranty Guarantee! Serving the Dallas,Texas DFW MetroPlex for Over 10 Years! Clean job sites, Quality work. Service You Can Trust! M-39887
PrecisionPlumbing is offline
Old 03-08-2011, 04:44 PM   #4
jmprPF
Thanks for the help with this topic!
jmprPF is offline
Do I need a plumber or a concrete guy? Chubba General Plumbing Help 1 07-22-2011 11:33 PM
Making a hole in concrete slab downtownguy General Plumbing Help 5 05-06-2011 08:27 PM
Bathtub on Concrete Slab supert160 Showers and Tubs 1 03-01-2011 07:09 PM
Concrete Wall in Shower jasmiesharris Showers and Tubs 10 02-03-2011 03:02 AM
Making a concrete sink. Chris Toilets and Sinks 6 04-24-2010 01:54 PM
Newest Threads
