Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Showers and Tubs > Bathtub on Concrete Slab
Thread Tools Display Modes
Old 02-27-2011, 11:21 PM   #1
Default Bathtub on Concrete Slab
I am installing a tub and shower in a bathroom reno on a concrete slab. The floor has been jackhammered, the existing 2" vented drain located and exposed. The tub is being dropped into a supporting wood frame that will ultimately be tiled. I intend on placing a concrete "second floor" to support the tub. I will install p-trap and stub out such that the tub can be connected to the drain. After the tub is dropped in place do you concrete over the hole that is exposed where the stub out exists, or can I stub out and repair slab before the tub is connected. Thanks
supert160 is offline
Old 03-01-2011, 07:09 PM   #2
Master Plumber
PrecisionPlumbing's Avatar
where the drain and water stub thru. place a card board box around it and concrete around the box. when it dries remove extra cardboard and fill inside with sand
‎(469)-248-2136 Precision Plumbing providing Service Repair Remodels Installing Quality Products With a Best Rate, Best Warranty Guarantee! Serving the Dallas,Texas DFW MetroPlex for Over 10 Years! Clean job sites, Quality work. Service You Can Trust! M-39887
PrecisionPlumbing is offline
PVC shower drain to cast iron in concrete slab--use Fernco no-hub coupling? (photos) studio460 Showers and Tubs 19 02-26-2012 01:55 AM
Do I need a plumber or a concrete guy? Chubba General Plumbing Help 1 07-22-2011 11:33 PM
Making a hole in concrete slab downtownguy General Plumbing Help 5 05-06-2011 08:27 PM
Rough-in for concrete over PVC DWV jmprPF General Plumbing Help 3 03-08-2011 04:44 PM
Bathtub Drain in a concrete slab floor NTLBM Showers and Tubs 5 01-12-2011 09:24 PM
Newest Threads
